Is My Breaker Going Bad, Or Am I Drawing Too Much Current? - Electrical - DIY Chatroom Home Improvement Forum
Old 05-21-2008, 12:08 AM   #1
Doing it myself
Alan's Avatar
Rewards Points: 2,140
Question
Is my breaker going bad, or am I drawing too much current?
My breaker for my garage has been popping lately. I normally don't use my compressor much, but lately I have, and it's been running for maybe 20 minutes at a time until the breaker finally pops. I was thinking that perhaps there is too much on that breaker (20A), but I turned off everything except the compressor and the 2 refrigerators that I have plugged in, and it still pops after about 20 minutes of use with the compressor. My compressor is just one of those small 8 gallon tanks on wheels...
Journeyman Plumber
Old 05-21-2008, 06:15 AM   #2
What's the amperage rating for the compressor, and each refrigerator? I wouldn't be suprised if all three compressors running at once could trip the 20A breaker.
NateHanson is offline   Reply With Quote
Old 05-21-2008, 09:22 AM   #3
Super Moderator
joed's Avatar
Rewards Points: 23,736
You have too much load on the circuit in my opinion. Compressor should be on its own circuit.
Old 05-21-2008, 07:57 PM   #4
Unplug the two fridges. Then try again, it probably won't happen. You'll have to get that compressor it's own circuit.
Super33 is offline   Reply With Quote
Old 05-22-2008, 10:20 AM   #5
Rewards Points: 306
I can't see a reason to put an 8 gallon compressor on a dedicated circuit. I would just limit the amout of devices (load) on that circuit. I have 15 gallon air compressor and have never had the breaker trip. But the circuit does not have much load on it. One freezer, four bench receptacles and two 8 foot flourescent lamps.
Unplug one fridge and see if the compressor trips the breaker.
Old 05-22-2008, 12:29 PM   #6
Power Gen/RS Engineer
Rewards Points: 566
The fridges have too much beer in them likely causing the overload.
Step one: Unplug compressor
Step two: Drink the beer
Well, now, there's what's right and what's right and never the twain shall meet.
BigJimmy is offline   Reply With Quote
Old 05-22-2008, 12:30 PM   #7
Super Moderator
joed's Avatar
8 gallons, 15 gallons means nothing electrically for a compressor rating. You need to specify the motor HP or FLA(both is best) to know if it belongs on a certain size circuit.
Old 05-22-2008, 11:46 PM   #8
Doing it myself
Alan's Avatar
Actually one of them does.
Journeyman Plumber
Old 05-23-2008, 01:30 AM   #9
You are overloading the circuit and your breaker may be getting weak from running it at peak load. Putting the compressor on its another circuit would most likely eliminate the problem. The most likely time it kicks out is whem one of the friges kicks on. The load spike is the culprit.
Holden McGroin is offline   Reply With Quote
Old 05-23-2008, 11:04 AM   #10
me
Rewards Points: 514
Darn, CA is to far for BigJimmy and I to travel to, or we would be happy to help you get rid of that. We would even rewire the place while we were there.
Add up the nameplate loads for the fridges and compressor and compare it to the circuit capacity. Move one to another circuit. Or unplug one fridge when you use the compressor. Not the beer fridge, you gotta have priorities.
jrclen is offline   Reply With Quote
This doesnt seem right. JoulesWinfield Electrical 27 07-26-2009 07:40 PM
Sub-panel grounding question. gesoneguy Electrical 31 02-22-2008 08:25 AM
Circuit breaker panel - Advice needed justtired Electrical 15 12-13-2007 05:55 AM
Sub panel grounding sluggermike Electrical 27 11-11-2007 01:23 AM
Outdoor breaker panel questions lhoney2 Electrical 12 07-19-2007 05:44 PM
