Multiwire Branch Circuit - Electrical - Page 3 - DIY Chatroom Home Improvement Forum
Old 03-12-2010, 06:53 AM   #31
Rewards Points: 2,800
That style of handle tie may be for manual turn off only and may fit too loosely to turn off both halves of the circuit in case of an overload that trips one breaker.
Also some breakers have a loose enough internal linkage so that tripping does not move the handle far enough to turn off other breakers linked to it.
Most cautions regarding multiwire branch circuits have to do with working on the wiring in which case the handle tie ensures that you turn off both halves.
Stick to your lawn watering schedule until it really starts to pour. After the storm you have only the same number of rest days you always had and then you need to start watering again.
Old 03-12-2010, 06:59 AM   #32
Just call me Andrew
Rewards Points: 1,032
But will it prevent just one breaker from tripping, because the other one is holding it ON?
Andrew
secutanudu is offline   Reply With Quote
Old 03-12-2010, 07:01 AM   #33
Master Electrician
Rewards Points: 5,082
2 pole breakers are designed with common trip. Using handle tie on two single pole breakers does not provide a common trip, it isn't supposed to. The purpose of a handle tie is to provide a common manual opening of both circuits. Either breaker will still trip upon an overload or short circuit.
brric is offline   Reply With Quote
Old 03-12-2010, 07:03 AM   #34
Just call me Andrew
Makes sense.
I just don't see how one could trip without the other, since they are tied together. How can one move without the other?
Or...would a breaker handle not move to the off position if it is tied to another breaker? Meaning you would have to turn both breakers OFF then ON to reset a tripped breaker.
Andrew
Old 03-12-2010, 07:15 AM   #35
Master Electrician
A breaker does not trip to the off position. That is why you must push it to off and then to on to reset it from the tripped position.
Old 03-12-2010, 08:45 PM   #36
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 528
Personally I would just install a double pole breaker and call it even.
Old 03-12-2010, 09:33 PM   #37
Just call me Andrew
I just went back to my friend's house to help finish this electrical project...turns out the two breakers in this MWBC are not even anywhere near each other in the panel....guess the electrician who did his house didn't do things right.
Andrew
Old 03-30-2010, 11:56 PM   #38
" Euro " electrician
frenchelectrican's Avatar
I have see worst than that.,,
I have one load centre in commercal building that have three phase supply try to find all the MWBC in that load centre was fun allright { the whole place have conduit so there is no MC or BX or Romex to simpleify it } that load centre have 14 3 MWBC's there { 42 total circuits there and all are 20 amps @ 277 volts !! }
Not always electrician put them in odd place some case home owner may put it on wrong spot or not group it but commercal location that diffrent story a simple answer a unqualifed person mess around the system like above that was time comusing task to sort it out.
Merci,Marc
Need a wiring diagram Mooreski Electrical 47 02-01-2015 03:07 PM
Tripping breakers,neutrals,120 volts and 240 volts OH My!!! Stubbie Electrical 17 06-11-2011 06:09 AM
Sharing Neutrals on the same phase electro Electrical 30 08-12-2010 02:10 PM
Can I change where power enters a branch circuit? RST Electrical 15 07-21-2009 07:38 PM
multiwire branch circuit question Jeremy Hillary Boob, PhD Electrical 9 11-18-2008 03:16 PM
