Multiple Circuits/one Switchbox - Electrical - DIY Chatroom Home Improvement Forum
Old 02-04-2012, 06:48 AM   #1
Rewards Points: 77
Multiple circuits/one switchbox
I am doing a residential rewire and adding some 3 way switches. My setup has me with switches controlling fixtures on more than one circuit in the same switchboxes.
I have done some research and I have not found any indication that this is a code violation. I am aware I cannot connect the neutrals from different circuits.
My question is, how do you guys handle this when wiring a home? Any tips as far as flagging the situation? Do you tie the breakers?
Just want to maintain safety and good workmanship
Thanks!
Mikenra is offline   Reply With Quote
Old 02-04-2012, 08:59 AM   #2
Rewards Points: 3,034
No special treatment is needed outside the box when wires from two different branch circuits (separate cables, separate neutrals) enter the same switch box, outlet box, or junciton box.
It is not necessary to tie the handles to the respective breakers.
Connect all ground wires (equipment grounding conductors) from all circuits together inside the box.
Stop some of your bank autopayments so you can set priorities for manual monthly payments out of your coronavirus stimulus check.
Split receptacles, double pole breakers and multiple circuits in a junction box. morganhammer Electrical 6 04-05-2011 04:38 PM
Basement lighting circuit - multiple lights and switches, end of circuit cmyk Electrical 2 03-03-2011 02:39 PM
Wiring Lights and Running Multiple Circuits in Conduit mark_anderson_u Electrical 0 11-02-2010 09:06 AM
Ground wire when multiple branches run through same conduit Ptron Electrical 25 08-09-2010 04:38 PM
minimum impact switchbox sherlock Electrical 5 10-20-2005 06:34 PM
