DIY Chatroom Home Improvement Forum (https://www.diychatroom.com/)
-   Electrical (https://www.diychatroom.com/f18/)
-   -   multiple 220 outlets wiring help (https://www.diychatroom.com/f18/multiple-220-outlets-wiring-help-84712/)
Xapex 10-23-2010 02:27 PM
Here's the details.
I am renting an office in a warehouse. I need to installed 2 - 220 20amp outlets for my computer servers. the length of the run is 76ft. there is 4 90 degree bends in the run. All the existing electric is run above the office ceilings and is in rigid or flexible metal conduit. I have run a few 110v circuits but never any 220v.
My questions:
do I run one 220v, 40amp circuit or 2 - 220v - 20 amp circuit.
what kind of conduit ( pvc, rigid metal, flex metal)?
what size conduit?
What size wire?
solid or stranded wire?
if i run 2-220v, 20 amp circuits do i run two whites and two grounds?
my current thinking on this is to run one 220v, 40 amp circuit. the run will terminate on top of the wall above where I need the outlets. i would split the circuit there and run the two legs to the outlet boxes in the office wall.
I would use 3/4" pvc conduit and pull 4 #08 wires, red, black,white and a ground. I would use 3/4" flexible plastic conduit to run the outlet legs down the wall to the outlet boxes.
any and all answers and comments appreciated.
TIA
Apex
Speedy Petey 10-23-2010 03:53 PM
Since this is a commercial space you are renting you have no choice but to either hire a professional to do this, or have the LL hire someone.
DO NOT mess with the electrical systems in a place you do not own!
I will say, your "current thinking" is fatally flawed.
Two 20A circuits does not equal one 40A circuit.
secutanudu 10-23-2010 06:19 PM
Speedy is right - hire a professional or risk hurting yourself and/or your computer equipment.
frenchelectrican 10-23-2010 09:52 PM
To OP I did see your statement and I allready reply in the other fourm and I will repeat in here just get a electrician and they will deal with it due it a commercal building and the DIY forum will not tell you what to do in commercal building beside hire a electrician.
And the question you been asking that kinda raised red flag allready to moi.
Merci.
Marc
Xapex 10-25-2010 09:25 AM
220
Thanks you all for your input
Powered by vBulletin® Version 3.8.8
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
