Multibranch Circuit - Electrical - DIY Chatroom Home Improvement Forum
Old 02-16-2014, 09:16 PM   #1
Rewards Points: 83
Multibranch circuit
So I am trying to figure out something, and learned it is called a multibranch circuit. In my electrical panel I have a 20A breaker for the dishwasher and a 20A breaker for the Disposal, and a tie-bar connecting the two breakers. And I guess they do this to eliminate the need to run extra wires, but I was looking at this picture online, and when I follow the wires in the picture it looks like you have (2) 120V wires going to an outlet, how does this work? wouldn't that turn that outlet into 240V? In my house I have a similar set-up, one outlet under the sink, one plug for the dishwasher, and one plug for disposal, and both are 120v items, so why have two hot 120V wires going into the outlet, seems like that would double the power, normally you only have one hot wire that powers both. Thanks in advance for any info.
streetneons is offline   Reply With Quote
Old 02-16-2014, 09:19 PM   #2
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
If they used one duplex receptacle to plug the appliances in, then they would have broke the tab connecting the two terminals on the hot side. The neutral tab would stay intact.
Old 02-16-2014, 11:15 PM   #3
Rewards Points: 2,528
No it wouldnt if the tab was broken on the hot side of the duplex
hammerlane is offline   Reply With Quote
Old 02-17-2014, 12:09 AM   #4
Rewards Points: 83
Ok it makes sense now. Thank you for the help!
Circuit breaker not returning everything to power after switched back on sam112 Electrical 7 02-10-2013 12:48 AM
Power in circuit, but not at outlets Sandmonkee Electrical 15 01-20-2013 12:11 PM
Dead circuit, couldn't find problem so tied into second circuit zappy12 Electrical 25 12-13-2012 09:38 PM
Changing a 3 way circuit...using recessed lighting box as a junction box? Oxymoron Electrical 1 12-07-2009 06:46 PM
