Multi-power Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 04-13-2010, 08:59 AM   #1
cowboy dan's Avatar
multi-power switch
where can i find a switch that could turn on my dust collector when one of various power tools are turned on? it's not a conventional piece.
it's for table saw, band saw, radial arm saw, and a sigle port for my various sanders.
cowboy dan is offline   Reply With Quote
Old 04-13-2010, 09:08 AM   #2
Master Electrician
Rewards Points: 5,084
rockler.com
brric is online now   Reply With Quote
The Following User Says Thank You to brric For This Useful Post:
cowboy dan (04-13-2010)
Old 04-13-2010, 10:54 AM   #3
cowboy dan's Avatar
Originally Posted by brric View Post
rockler.com
thanks can you think of a price range?
Old 04-13-2010, 11:01 AM   #4
fabrk8r
fabrk8r's Avatar
Intelligent plug-in switch automatically controls a vacuum or dust collector through the power tool’s on/off switch! Eliminates continual running of vacuum to preserve the vacuum motor life. Ideal for miter saws, table saws, sanders, routers and planers. Easy to install — just plug it in!
http://www.rockler.com/product.cfm?p...&filter=SWITCH
Price is listed in the link.
"The physician can bury his mistakes, but the architect can only advise his clients to plant vines." -- Frank Lloyd Wright
fabrk8r is offline   Reply With Quote
Old 04-13-2010, 01:25 PM   #5
cowboy dan's Avatar
thanks for the link, i was wanting that for my 110 tools, but what about my table saw and band saw. they are 110 at the moment but when i get my sub panel installed those larger tools will be on 240. any thoughts?
Old 04-13-2010, 01:40 PM   #6
Get a 24vac relay or relays which contacts can handle a motor load at the current you need or will be needing. Hosfelt.com and others sometimes have great prices for this things.
Then you switch all the relays simultaneously with almost any switch and any 24vac transformer.
The Following User Says Thank You to Yoyizit For This Useful Post:
Old 04-13-2010, 01:42 PM   #7
fabrk8r
fabrk8r's Avatar
You could just buy a 240V double-pole single-throw switch. If you want the ability to just turn the saw on at times without the duct collection system starting, get a double-pole double-throw switch.
McMaster-Carr has them.
http://www.mcmaster.com/#lighting-controls/=6n8ub9
The Following User Says Thank You to fabrk8r For This Useful Post:
Double switch wiring rockclimber Electrical 18 03-18-2012 10:13 PM
Just for fun Andy in ATL Electrical 56 10-20-2009 09:33 AM
Power from Fixture to Switch Not working madjoseph Electrical 5 09-26-2009 02:57 PM
no power to light switch diople Electrical 6 05-16-2009 01:40 PM
Adding a Switch and jump power Bull-37 Electrical 9 01-10-2008 05:45 PM
