Multi Outlet / Light Wiring Question - Electrical - DIY Chatroom Home Improvement Forum
Old 02-03-2012, 02:52 PM   #1
Rewards Points: 155
multi outlet / light wiring question
as far as i understand all outlet or light are wiring in parallel circuit. so why does this graph said its in series, and it look like the circuit is same as the 2nd link, except one is pigtail and one is screw.
http://www.do-it-yourself-help.com/w...ceptacles.html
http://www.buildmyowncabin.com/elect...ms-outlet.html
also for light fixture i can wire parallel like this? i pretty sure it can but like to verify it.
s002wjh is offline   Reply With Quote
Old 02-03-2012, 03:10 PM   #2
outlets are wired in parallel. the diagram is correct that you referred to but they definitely described it incorrectly. i asked them that question and am waiting for a reply.
Old 02-03-2012, 05:08 PM   #3
I=E/R
a7ecorsair's Avatar
It doesn't say they are "in series."
It says they are in a series.
2 or more receptacle outlets in a series
Maybe just a poor choice of words for electrical description.
a7ecorsair is offline   Reply With Quote
Old 02-03-2012, 05:45 PM   #4
Super Moderator
joed's Avatar
Rewards Points: 30,890
The one I am looking at says "Wiring Multiple Receptacles in Series".
Poor choice of words, probably by someone who knows nothing of electrical terms series and parallel.. They are in fact wired in parallel.
Old 02-03-2012, 06:14 PM   #5
Rewards Points: 155
ok thanks btw, the lighting fixture diagram that I drawn is ok? i mean i can connect that way?
Old 02-03-2012, 07:17 PM   #6
Super Moderator
joed's Avatar
Yes you can. Match all the colours at the fixtures.
Old 02-03-2012, 07:45 PM   #7
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
Pigtail the wires before each plug/fixture,dont use the plugs/fixtures as a junction point
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
Old 02-03-2012, 08:35 PM   #8
Rewards Points: 155
i see, why is that though? i would thought use the plug/fixture screw to connect both same color wire would be fine?
Old 02-04-2012, 10:23 AM   #9
Super Moderator
joed's Avatar
Only one wire is permitted to be under a screw.
Basic wiring question when changing light fixture diydan Electrical 3 10-18-2011 06:29 AM
Light controlled by switch, outlet always on, power at light...is this the way? pureevil Electrical 6 11-07-2010 05:32 PM
Closet question: options and wiring diagram? schnitz411 Electrical 6 10-24-2009 11:45 AM
Help wiring ceiling light wylde8 Electrical 1 09-24-2009 06:29 AM
wiring in a light fixture to an existing outlet tjc460 Electrical 8 05-26-2008 09:32 AM
