Multi Out Hardware ? - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 12-18-2010, 01:22 AM   #16
" Euro " electrician
frenchelectrican's Avatar
Originally Posted by billy b View Post
ok what i did today was
1.ran the wire to a junction with two wire's coming out
2. ran one wire to room 1 of 2 to a GFCI recpticle and from this ran another wire to the 2nd recpticle in room
3. repeated with other wire out from junction box for room 2 of 2
3. lowered fuse to 25 amp
4. placed junction box under mobile home out of way of water when it rains
5. pluged in main and it all works i just hope my dads friend says its ok
thanks for all the advice
First thing first .,
Can you tell me what size cable you ran you should see the marking on the cable it will tell you what size AWG it is.
Which part of the room you are installing in ?
If in bedroom normally they don't use the GFCI but with new circuits it have to be AFCI {I am pretty sure your local code do require it }
Oh by the way do not tap into bathroom or kitchen circuits they are off limits per NEC codes.
Still do NOT use the 25 amp fuse on this circuit you have to get a 20 amp fuse unless you have specal fuse socket which it will be smaller than standard fuse socket size if that the case unscrew the fuse and take a flashlight and shine in there and see the marking or colour and let us know we will tell you what size it take.
Really there is no excuse to use the 20 amp fuse { get with time delay type I know cost more but reduce the chance to blow out real quick }
I wish you should wait until you talk to your dad's freind first to give you a correct way to do this before it get out of the hand or volitated the codes.
Merci,
Marc
Old 12-18-2010, 07:34 AM   #17
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 2,006
I'll repeat, again, at the risk of being redundant. YOU CANNOT USE A 25A FUSE.
General receptacle circuits MUST only be on a 15 or 20A fuse.
I'm not sure how you missed this one since several of us have said this several times.
Your dad's friend the electrician is WRONG. It is NOT ok.
Old 12-18-2010, 08:48 AM   #18
awg is 12
i will switch to a 20 amp fuse
and i will buy AFCI's to switch the out with the GFCI's
just the two wall sockets
he may be wrong when he gets here but i have not even spoke to him directly yet..
hopefully this will get things right
thanks again for helping this beginner
billy b is offline   Reply With Quote
Old 12-18-2010, 08:53 AM   #19
Sorry, I misread where you said you hope he says it's ok.
I though he gave it the thumbs up already.
Old 12-18-2010, 09:07 AM   #20
i may have even found the culprit of why there was no electricity in the first place.
theres a socket hidden behind the paneling in the bathroom that has the insulation burned off one of the black wires probably from having a 30 amp fuse plugged in for years lol
so i guess im back to sqaure one. cut the burned wire back to a stable point move the socket there after replacing with a new one then look for any other hidden sockets lol again
then see if it works and do away with my possibly shody work
Old 12-18-2010, 09:27 PM   #21
Rewards Points: 150
One thing keeps occurring to me in this thread... that it's an example where someone believes "it works, so it must be right".
An outlet wired directly to the line side of the main breaker with zipcord will "work", as long as nothing ever goes wrong, but I don't want to be anywhere near the house when a mouse chews through the wire insulation!
emolatur is offline   Reply With Quote
Pella Storm Door Hardware Crosseyed08 Building & Construction 0 04-23-2010 07:17 PM
Pocket door - Need hardware HELP Gawthorne Carpentry 3 03-08-2009 09:55 AM
Sliding Closet Door Hardware suggestions jpsmith Carpentry 7 02-27-2009 03:23 PM
Bifold door hardware hel handylady Carpentry 1 10-28-2008 06:45 PM
