Multi Out Hardware ? - Electrical - DIY Chatroom Home Improvement Forum
Old 12-17-2010, 07:26 AM   #1
multi out hardware ?
Could anyonne tell me what i need ?
I have two bedrooms without electricity .I already have a single wire ( meaning a single wire with white,black and copper uninsulated ) running under the house not connected to anything anymore and running off a 30 amp fuse. I want to know is the anything i can connect that wire to that has a multi out interface so i can run multiple wires from it to multiple outlets , 4 in all 2 per room
Thanks in advance
billy b is offline   Reply With Quote
Old 12-17-2010, 07:35 AM   #2
the Musigician
DangerMouse's Avatar
Too many variables to correctly answer your question.
What is this wire going to feed? What gauge is it?
If it's for a bedroom, it needs an AFCI breaker. (15 amps, not 30)
You need separate lines and AFCI breakers for each bedroom.... etc....
DM
Old 12-17-2010, 07:41 AM   #3
I=E/R
a7ecorsair's Avatar
Thanks in advance
You said 30 amp fuse so does that mean it is really a fuse. Step one, as DM said, is to figure out is the wire size that makes up this cable.
a7ecorsair is offline   Reply With Quote
The Following User Says Thank You to a7ecorsair For This Useful Post:
billy b (12-17-2010)
Old 12-17-2010, 08:15 AM   #4
room 1=its going to feed 55inch tv,xbox 360,surround sound and a lamp
room 2 = 36 inch tv + sat+dvd player and a lamp (12,000 btu window unit in summer but its new and claims it has less pull on juice)
and im sorry im not sure what gauge the wire is all the writing is sun faded on wire but if it helps its thicker than the existing wire in my houses outlets it was originaly wired for a large outdoor light on a pole at the end of my driveway.
i can lower the fuse size to 25 amp (tried and worked)but its already tied into the fuse box thats why i wanted to use it instead of rewiring at the fuse box to add a 15 amp fuse(im not confident enough to try that yet)
yes there fuses i forgot the name maybe edison or somthing there ceramic screw in type
is it not safe to use a 25 amp fuse ? cause i have it hooked up to tv and xbox 360 right now i just poked through the floor and connected 1 outlet temporarily
thanks for helping
Old 12-17-2010, 08:34 AM   #5
Electrical Contractor
jbfan's Avatar
Rewards Points: 980
The receptalces can not be on any fuse larger than 20 amp.
Yes I am a pirate, two hundred years too late
The cannons don't thunder, there's nothing to plunder
I'm an over-forty victim of fate.
The Following 2 Users Say Thank You to jbfan For This Useful Post:
billy b (12-17-2010), Speedy Petey (12-17-2010)
Old 12-17-2010, 08:34 AM   #6
the Musigician
How long is your driveway?
DM
Old 12-17-2010, 08:39 AM   #7
just 2 car lengths lol
so i guess i cant use this wire for juice then ,because its 25amp instead of 15 or 20 ?
i dont need it to pass inspection i just dont want to burn the house down lol
Old 12-17-2010, 08:45 AM   #8
the Musigician
I don't see why not.
DM
The Following User Says Thank You to DangerMouse For This Useful Post:
Old 12-17-2010, 08:52 AM   #9
ok good i just didnt want to fry my electronics or burn the house down.
so as for a multi out is there not such a thing or do i just run the wire to one outlet then use the other screws on outlet to run wires to next outlet and so on ?
thanks for helping cause ive never dealt with home electric only cars.
Old 12-17-2010, 09:58 AM   #10
the Musigician
Please tell us you ARE going to permit this job and have it inspected.
Electrical work is something that truly needs to be done exactly right, or there can be all sorts of hazards possible, up to and including death. It's honestly not that difficult to do the job, (tedious and time consuming, yes) but it needs to be done the right way to be safe. Po)
DM
Old 12-17-2010, 10:03 AM   #11
the Musigician
... and yes, you just wire the first one, then white to white, black to black on to the next, and so on.
In the bedrooms, I had to put in an AFCI breaker to pass code, and I took it a step farther and used a GFCI as the first outlet in each room's run.
DM
Old 12-17-2010, 10:06 AM   #12
yes im going to go ahead and call my dads friend which is an electrician check it out to be on the safe side... thanks for all the help DM
Old 12-17-2010, 01:08 PM   #13
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 2,006
Just change the fuse to a 15 or 20, depending on the size of the wire. You MUST know the size of the wire to determine this.
I hate to say it but I feel you should NOT be messing with this. You obviously have no experience and considering this there is a very real chance you are going to make a mistake, even if it is unintentional.
Let your dad's friend the electrician do this job and maybe he will show you what he does.
The Following User Says Thank You to Speedy Petey For This Useful Post:
SD515 (12-18-2010)
Old 12-17-2010, 03:46 PM   #14
Rewards Points: 202
I agree; in fact I was going to suggest that this project sounded a little large for you, after reading your first post, but didn't want to sound harsh. You're only getting started, and based on your initial questions, and what you want to accomplish, this could turn into a year or longer project for you, by the time you search answers to each question that comes up. DIY is great, but a big part of it is knowing what you know, and knowing the right way to learn. But you have the ideal solution. As Pete said, let your dad's friend do it, and learn as he goes. Even without hovering over him, and even if you only see what he has done at the end of each day, you will learn a lot, I am sure.
Old 12-18-2010, 12:01 AM   #15
ok what i did today was
1.ran the wire to a junction with two wire's coming out
2. ran one wire to room 1 of 2 to a GFCI recpticle and from this ran another wire to the 2nd recpticle in room
3. repeated with other wire out from junction box for room 2 of 2
3. lowered fuse to 25 amp
4. placed junction box under mobile home out of way of water when it rains
5. pluged in main and it all works i just hope my dads friend says its ok
thanks for all the advice
Pella Storm Door Hardware Crosseyed08 Building & Construction 0 04-23-2010 07:17 PM
Pocket door - Need hardware HELP Gawthorne Carpentry 3 03-08-2009 09:55 AM
Sliding Closet Door Hardware suggestions jpsmith Carpentry 7 02-27-2009 03:23 PM
Bifold door hardware hel handylady Carpentry 1 10-28-2008 06:45 PM
