Moving The Meter - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 09-27-2009, 11:37 AM   #16
300zx's Avatar
Post
I have not seen one like that the one that we use has breaker space so you could feed the garage here is a small pic and link http://www.hardwareandtools.com/invt/8272296 http://www.idealtruevalue.com/servlet/the-175996/Detail
300zx is offline   Reply With Quote
Old 09-27-2009, 12:55 PM   #17
So I could basically install that, tap power for the garage and feed power to the house so my box there now would become the sub-panel of the main combo on the garage ? Mind you, I will be calling an electrician to do all of this, but it is possible?
Manicmech is offline   Reply With Quote
Old 09-27-2009, 01:08 PM   #18
300zx's Avatar
Post
Do you have a meter and a panel outside or just a meter ? is it 200 amp now ? You will prob need to have the power co. send a Engineer out and confirm your plans
Old 09-27-2009, 02:43 PM   #19
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
Originally Posted by Manicmech View Post
but it is possible?
As 300 says now is the time to get the Power Company involved. Unless you already know their requirements for vertical clearance and distance and who knows what else.
Disclaimer
& Stay Safe
.....Bob Lavery
Old 09-28-2009, 06:24 PM   #20
Just a meter, 200 amp service, called power company today... thanx
Old 09-28-2009, 06:32 PM   #21
300zx's Avatar
Post
If its just a meter they could put that meter main right where the meter is now and then run a line from there to your garage. Let them know your plans and see what they say.They could also give you some ideas because they will see the project. Keep us updated
Old 09-29-2009, 05:45 PM   #22
Sounds good, thanks 300
Tiny elbows on meter? pcampbell HVAC 24 10-06-2009 09:54 AM
Replacing and Moving a Fuse box with a breaker box nightrook Electrical 18 09-24-2009 07:49 PM
Water meter aggravations Ultrarunner2017 Plumbing 8 03-21-2009 06:53 AM
Frozen water meter stubborn1 Plumbing 5 01-26-2009 06:35 AM
Moving Water Meter bkeech Plumbing 11 06-15-2008 09:35 PM
