Moving Dryer - Electrical - DIY Chatroom Home Improvement Forum
Old 09-05-2010, 11:16 AM   #1
Moving dryer
I am moving my dryer to another location. I will be running the wires through the attic. Do I need to derate the wires due to the heat in the attic. It has a 30 amp, 240 volt circuit. Can I use #10 NM. The distance is approx. 65 ft. The max. outdoor temp. is 100 degrees, inside the attic ???
plugnec is offline   Reply With Quote
Old 09-05-2010, 12:08 PM   #2
Where are you located ?
How hot does the attic get ?
Old 09-05-2010, 01:31 PM   #3
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 528
If you can, keep them under the insulation, and not over. Not always easy. Sometimes you can split a batt in half (just by ripping it with your hands) so you can pass it "through" the insulation. I've done that before where the wire was passing through the joists at the half way mark (normally how it is).
Though, I'm pretty sure most romex is rated at like 100 degrees or something like that.
Old 09-05-2010, 02:09 PM   #4
A "Handy Husband"
rjniles's Avatar
Rewards Points: 704
NM cable made for since 1984 has been rated for 90 degrees C (194 degrees F.). I doubt that your attic could get hot enough to exceed that. Run your cable on top of the insulation. You will disrupt your insulation by trying to get the cable below it and cause heat leak problems.
You do not have to derate the cable for temp. or the 65 feet.
My electrical answers are based on 2014 NEC, you may have local amendments.
Old 09-05-2010, 03:22 PM   #5
While it is rated for 90c you are supposed to derate when ambient temps exceed 86f per table 310.16
For an attic that gets extremely hot you may need to derate quite a bit
And since you need 30a for the dryer that means going to a larger wire size
Is your attic vented ?
Old 09-05-2010, 05:12 PM   #6
A "Handy Husband"
rjniles's Avatar
Rewards Points: 704
Dave,
While I am sure that you are reading the code correctly, I have never seen a 10-3 (30 amp) dryer cable or a 10- (30 amp) water heater cable derated or the wire size up to account for running in a hot attic. I live in SC and the attics get pretty hot.
Usually these appliances (dryer or water heater) use well under 30 amps, so that even a derated 10 ga cable is sufficient.
Edited to change my mis-use of 12 when I meant 10 ga.
Old 09-05-2010, 05:15 PM   #7
Registered User
Rewards Points: 526
http://www.diychatroom.com/f18/over-...n-attic-79469/
Try not to compress the insulation, if you have any ice dams above it this winter, you'll know why.
Gary
Old 09-06-2010, 12:42 AM   #8
" Euro " electrician
frenchelectrican's Avatar
Just make sure you have 4 wire dryer cord and receptale once you move the dryer to new location it allready written in the code for a while { 1996 that when it kick in }
Merci.
Marc
Moving Washer and Dryer upstairs from basement pennypoopie General DIY Discussions 3 08-23-2009 05:29 PM
moving my washer and dryer coastalcomplete Plumbing 4 03-03-2009 09:45 PM
Moving washer and dryer into Garage, perhaps some constucion needed? J187 Building & Construction 4 05-21-2008 11:53 AM
moving gas dryer sonofthetonsured Appliances 12 07-07-2007 10:56 PM
Moving washer/ dryer from 1st to 2nd floor sebastien1 Remodeling 33 11-08-2006 09:31 AM
