Mounting An Electrical Box 90* To Normal? - Electrical - DIY Chatroom Home Improvement Forum
Old 01-14-2016, 02:41 PM   #1
Rewards Points: 1,052
Mounting an electrical box 90* to normal?
I have a box attached to the side of a joist in the normal fashion, a ceramic light fixture on it, and a small LED light screwed in.
I would like to remount the electrical box with screws through the bottom of the box so that it is 90* normal. That would effectively raise the level of the light 6" so that people don't have to look at the bulb.
Any code issues with this?
Toller is offline   Reply With Quote
Old 01-14-2016, 03:41 PM   #2
Rewards Points: 18,046
There's no reason it can not be turned 90 deg. but you can not add screws inside the box.
Going to have to open up the wall and add a horizontal 2 X 4 to attach it to.
Old 01-14-2016, 04:05 PM   #3
Master Electrician
Rewards Points: 5,120
Why no screws inside the box?
brric is online now   Reply With Quote
The Following 2 Users Say Thank You to brric For This Useful Post:
danpik (01-15-2016), mpoulton (01-15-2016)
Old 01-14-2016, 04:05 PM   #4
A "Handy Husband"
rjniles's Avatar
Rewards Points: 50
Are you talking about a box mounted on the joist with an unfinished ceiling (like a basement?
My electrical answers are based on 2014 NEC, you may have local amendments.
Old 01-14-2016, 04:58 PM   #5
Licensed electrician
Rewards Points: 3,670
Screws through the back of a 1900 box is a common practice.
To OP, what type of box are you planning on using?
Old 01-14-2016, 05:49 PM   #6
Oso954's Avatar
Rewards Points: 70
I think he's saying rotate the entire box, fixture, and bulb up into the bay between the joists. In other words, the bulb horizontal above the bottom of the joist rather than the fixture/bulb below the joist with the bulb hanging down.
Oso954 is offline   Reply With Quote
Old 01-14-2016, 10:09 PM   #7
Rewards Points: 1,798
Use an old work box?
ktkelly is offline   Reply With Quote
Old 01-15-2016, 10:25 AM   #8
Master Electrician
Why use an old work box for exposed work?
Old 01-15-2016, 10:49 AM   #9
I saw no mention of it being exposed.
Old 01-15-2016, 11:21 AM   #10
Master Electrician
Where would you find a non-exposed porcelain lamp holder?
Old 01-15-2016, 01:41 PM   #11
Rewards Points: 299
How else does one mount a metal box if not by screwing through the holes in it?
Syberia is offline   Reply With Quote
Old 01-15-2016, 02:29 PM   #12
Correct
Old 01-15-2016, 02:30 PM   #13
Exactly. It is a blue plastic box.
Old 01-15-2016, 02:41 PM   #14
Rewards Points: 422
There is no Code violation to mounting a box in between joists (to the underside of the subfloor) in an unfinished basement.
Pharon is offline   Reply With Quote
Old 01-15-2016, 03:07 PM   #15
Oso954's Avatar
Rewards Points: 70
I don't think you are allowed to drill/screw your own mounting holes in plastic boxes unless they are at points designated/allowed by the mfg.
I would change the box.
New Basement Bathroom / Laundry Room Electrical Circuit(s) Rookie11 Electrical 5 12-11-2012 09:52 PM
Electrical loading question jimcorey Electrical 2 12-08-2012 08:27 AM
Changing from Electrical Cook Top to Electrical Range EkS Electrical 24 06-22-2010 11:43 AM
Mounting Checkolite pot rack with lighting Warner Electrical 2 06-16-2010 02:56 PM
Just for fun Andy in ATL Electrical 56 10-20-2009 10:33 AM
