Mounting The Ceiling Fan... - Electrical - DIY Chatroom Home Improvement Forum
Old 01-16-2010, 02:13 PM   #1
Mounting the ceiling fan...
Hi
I am remounting the ceiling fan and light to the center of the kitchen from it's original location which was near one corner of the kitchen. I punched a hole at the center and turned out that there is a ceiling joist perfectly next to the hole. Hate when that happens. I am seeing two options, actually three.
One: This one is actually a question. The drywall is 1/2". Is there a 1/2" junction box? If so, then I can screw that into the ceiling joist as well as a 2x4 bracket going between the joists.
Two: Mount the 2x4 bracket between the joists over the punched hole and drill perhaps using a 1/2" bit through it. Run the wires from the fan/light fixture through the hole and into the junction box above the 2x4. Make the connection with the black and white wires there and cover it. Is this method to code?
Three: Move the center hole off to one side (1 3/4") enough to put the junction box right next to the joist. My wife and I prefer not to go this route because the off center may be obvious. If option one and two can not be done, then option we have no choice but to choose option three.
Unless there is another option you can come up with, let me know. I appreciate any inputs. Thanks!
Eagle2
Eagle2 is offline   Reply With Quote
Old 01-16-2010, 02:46 PM   #2
Residential Contractor
The thin box you are wondering about does exist. It's called a pancake box. It's round and approx 1/2" thick. I've always bought them at my supply house, but HD or the other big boxes may carry them too.
Dont forget to ground the fan via the green wire.
Edit-looks like this
rselectric1 is offline   Reply With Quote
Old 01-16-2010, 03:25 PM   #3
Thanks! I will look for it and buy it.
Old 01-17-2010, 06:53 AM   #4
Master Electrician
JohnJ0906's Avatar
Get one that is rated for ceiling fans - the one pictured is not. If you use one like the above, you will need to support the fan independently of the box.
John from Baltimore
One Day at a Time
"Experience is what you get when you were expecting something else"
"The bitterness of low quality lingers long after the sweetness of low cost is forgotten"
JohnJ0906 is offline   Reply With Quote
Old 01-17-2010, 12:01 PM   #5
Master Electrician
richgriffith's Avatar
you need get one thats rated for paddle fans like the one below.
richgriffith is offline   Reply With Quote
Old 01-17-2010, 01:42 PM   #6
Inspector/Instructor
codeone's Avatar
Heres another solutions
codeone is offline   Reply With Quote
Old 01-23-2010, 08:43 PM   #7
JohnJ0906, richgriffith, codeone
Thanks for your replies. richgriffith, the image didn't show up.
I bought the metal type and screw that into the 2x4 which is between the joist and also screwed in. The result is rock solid so I went ahead and installed the light/fan fixture. If this fails down the road, I will get the junction box meant for the ceiling fan.
Thanks again.
Old 01-23-2010, 09:06 PM   #8
Question
Thanks again.
The reason we need to install boxes APPROVED (for ceiling fans) is that sometimes, even though the original installation is ROCK SOLID, the fan can get separated from the box (threads not strong enough) especially when the HIGHEST speed is used for an extended period. The vibrations are, sometimes excessive, possibly due to a (slight) imbalance of the fan.!
spark plug is offline   Reply With Quote
Ceiling Fan mounting Big Bill General DIY Discussions 8 02-07-2010 08:07 PM
Ceiling condensation icemand Building & Construction 1 12-15-2009 05:16 AM
Old ceiling replacement idsp General DIY Discussions 12 07-25-2009 10:48 AM
Mounting Ceiling Fan to Exposed Beam zero1niner Electrical 7 05-05-2009 11:41 AM
Pot lights in a drop ceiling Howdy Electrical 3 03-14-2008 08:23 PM
