Mount Ceiling Fans To 3" Insulated Aluminum Panel Roof - Electrical - DIY Chatroom Home Improvement Forum
Old 06-19-2010, 10:34 AM   #1
Mount Ceiling Fans to 3" insulated aluminum panel roof
Need to mount ceiling fans to a 3" thick insulated aluminum roof that does not have the fan beams inside. Concerns over leaking and sufficient support topside to prevent pull through?
jayarce is offline   Reply With Quote
Old 06-19-2010, 10:47 AM   #2
Electrical Contractor
kbsparky's Avatar
Take a steel plate (a 1900 or 2100 box blank plate will do) and drill a couple of holes in it that align with the mounting holes of a box suitable for fan support.
You will have to drill a couple of holes from the ceiling inside completely through to the roof. Use the steel plate for reinforcing support. We use urethane caulk on the top plate to keep any water intrusion out.
We also double-nut the fan box on the underside to prevent the assembly from trying to crush the ceiling panel. Results using this method have been excellent on past projects.
-KB
The Following User Says Thank You to kbsparky For This Useful Post:
andrew79 (06-19-2010)
Old 06-19-2010, 12:28 PM   #3
Master Electrician
nice idea kb....mind if i steal it if the need arises
andrew79 is offline   Reply With Quote
Old 06-19-2010, 01:19 PM   #4
Thank You, KB. I shall install just as you suggest.
Old 06-19-2010, 03:49 PM   #5
Your fan is under 35 pounds?
Old 06-20-2010, 08:23 AM   #6
Under 35#'s - Yes
Yes, fans are under 35#s.
Tags
ceiling fans! , roofing panels
Ceiling Fan Surface Mount to Drop Mount hbv2020 Electrical 1 02-20-2010 08:24 AM
Ceiling condensation icemand Building & Construction 1 12-15-2009 05:16 AM
Ceiling mounted clothes rod (one side wall mount, one side ceiling mount) DCA General DIY Discussions 9 08-17-2009 10:13 AM
Insulating Aluminum roof rebrich1 Roofing/Siding 1 03-27-2007 06:54 PM
Flat roof - Rolled? - leaks Advice? JJ2001 Roofing/Siding 4 11-19-2006 06:17 AM
