Motion Switch For Garage - Electrical - DIY Chatroom Home Improvement Forum
Old 02-19-2010, 01:41 AM   #1
Rewards Points: 422
motion switch for garage
I want to turn on all the garage lights ( 4 , 8 foot twin tube fluorescents )
when I pull in after dark. The garage door opener lights just don't cut it.
I'm thinking all I need to do is replace my on/off wall switch with this.
http://www.smarthome.com/2520W/Levit...r-White/p.aspx
I'm in northern Il. and garage ( insulated) temps do get down about freezing or a bit lower.
I noticed its only rated down to 32f .
What can I use ?
High Gear is offline   Reply With Quote
Old 02-19-2010, 01:55 AM   #2
Rewards Points: 81
I have four motion-triggered switches in my garage. I love it.
But I'm in Southern California, so I can't give an opinion on whether freezing temperatures will be a problem.
Jack Olsen is offline   Reply With Quote
Old 02-19-2010, 07:34 AM   #3
jlhaslip's Avatar
Rewards Points: 708
I have a motion sensor on my exterior garage lights that work at -30 o C just fine.
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is offline   Reply With Quote
Old 02-19-2010, 08:36 AM   #4
Just call me Andrew
Rewards Points: 1,032
Not sure on temp, but take a look at your local store, may be cheaper than that the site you linked.
Andrew
secutanudu is offline   Reply With Quote
Old 02-19-2010, 09:21 AM   #5
Rewards Points: 422
From what I've seen a lot of the box store switches max at 500W as
they're made for indoor use and wouldn't need high wattage's.
They seem to be specific to the type of ballast on the fluorescent also.
I'm not really sure on what type of ballast I have anyways , just know its
cold start .
This is a commercial rated motion switch in the link. Looks to work with
higher wattage's and all ballast types.
motion, photosensor, light switch to choose mode joshoc Electrical 5 12-18-2009 01:49 PM
Modification to an existing pump switch DRBLKJK Electrical 10 08-23-2009 04:06 PM
Motion switch wired to two circuits Sibkuz Electrical 2 04-22-2009 08:31 PM
Problem with motion sensor switch & light usseabeemom Electrical 5 11-17-2008 06:54 PM
Replacing a bathroom fan switch cmacjr22 Electrical 4 11-04-2008 07:14 PM
