Motion Sensor For Fluro With Electronic Ballast - Electrical - DIY Chatroom Home Improvement Forum
Old 12-27-2009, 04:53 PM   #1
motion sensor for fluro with electronic ballast
Anybody can recommend one for home use which can be used with wall plate.
the only one I've found is on ebbbay by keyword <PIR Wall switch occupancy sensors White MOS15-W> bigdealelectric_corp from Malasya for $40, seller says it's based on relay so work with any light, just not sure about this brand, + it says <required neutral wire> but it should be OK, normally it's in any outlet.
Dai
dainova is offline   Reply With Quote
Old 12-27-2009, 06:13 PM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 704
I would not assume you have a neutral in any switch box. Very often you will only have a switch loop without a neutral. I would open the switch and check before I bought the switch.
Old 12-27-2009, 08:45 PM   #3
" Euro " electrician
frenchelectrican's Avatar
That one key word check the switch if you have legit netural in the switch box if so the motion sensor should be rated for flourscent luminaires.
If you have flourscent rated motion switch make sure it have netural in there if not it will not function properly.{ this is true with electronic ballast verison }
Merci,Marc
Old 12-27-2009, 10:15 PM   #4
Merci Boku, Mark!
bit confused, I'm in US, and thought that here we always have neutral and hot on faceplate, not mentioned ground. I assume that if I measure "assumed neutral"-to- ground and have 0V it's real neutral.
Tx again
Dai
Old 12-27-2009, 10:27 PM   #5
Merci Boku, Mark!
Tx again
Dai
Dai.,
What I am refering the black and white conductor { wire } if your switch box only have one black and one white noting else in there that what we called switchloop but if you have two pairs like two black and two white it a good chance that you will have power there at the switch box.
Keep in your mind the ground { bare copper or green wire } are not used for netural purpose at all they only for safety in case something short out so that can trip the breaker or blow the fuse.
Hope that clear up that question you are looking for.
Merci,Marc
Old 12-28-2009, 05:51 PM   #6
CodeEnforcer
HIVOLT's Avatar
Rewards Points: 99
You can get a WattStopper Sensor at any electrical supply house. These are made so they do not need a neutral (white wire). These work on incadescent and flourescent (regardless if standard or electronic ballasts).
HIVOLT is offline   Reply With Quote
Wiring up an outside set of motion sensing lights airdaleairdale Electrical 1 06-11-2009 08:35 PM
Motion switch wired to two circuits Sibkuz Electrical 2 04-22-2009 07:31 PM
Motion flood "non-standard" wiring Fishin_Man Electrical 5 01-14-2009 03:20 PM
Electronic Ballast? fw2007 Electrical 9 03-18-2008 04:41 PM
