Momentary Touch Sensor For A Lamp - Electrical - DIY Chatroom Home Improvement Forum
Old 08-18-2015, 12:12 PM   #1
Rewards Points: 20
Question
Momentary touch sensor for a lamp
I'm working on building a lamp that I'm integrating a z-wave micro dimmer into, so that I can control it with my home automation system and everything is built into the lamp itself.
I also want to be able to make it work without automation. The micro dimmer module I'm using works with a momentary push button which can turn it of/on at a short press, or dim up/down with a press and hold. I'd like to use a touch sensor as a momentary push button, but so far I'm only finding dimmers, and a dimmer switch won't work with this application.
Can anyone recommend a touch sensor that acts as a momentary push button? The circuit it attaches to in the micro dimmer is a low-voltage circuit, so pretty much any touch sensor switch that acts as a momentary button would do.
Thanks in advance.
cue8chalk is offline   Reply With Quote
Touch lamp stopped functioning properly Spend Electrical 4 02-06-2014 11:05 AM
NOVICE fixing a Touch Lamp bearcat22 Electrical 10 04-29-2013 11:47 AM
Metal Lamp Touch Switch Module tarnall Electrical 2 12-12-2012 02:18 PM
Touch lamp turns on and off with fan switches in the house vseven Electrical 1 04-11-2010 09:18 AM
Wall-mounted touch switch lamp help davros72 Electrical 1 12-24-2006 01:13 PM
