Mixing Panel Brands - Electrical - DIY Chatroom Home Improvement Forum
Old 06-06-2010, 12:08 PM   #1
the Musigician
DangerMouse's Avatar
Mixing Panel Brands
I'm finding that with all the new stuff I have to do to the electric, I'm seriously needing a larger panel or a sub-panel to take up the slack.
Is it OK to mix, say, a Seimens panel and a Square-D with no inspector problems?
I see no reason why not, but I thought it best to double check, just in case.
Thanks!
DM
Old 06-06-2010, 12:27 PM   #2
Just call me Andrew
Rewards Points: 1,032
I can't see any reason why it's bad, other than inconsistency when working on one panel vs. the other.
Andrew
secutanudu is offline   Reply With Quote
Old 06-06-2010, 12:55 PM   #3
You can mix & match panels
But I prefer to stay with the same panels - easier to swap breakers if you need to
I have (3) Square D QO & (1) Square D Homeline (free) - came with 6 breakers I think
Old 06-06-2010, 01:10 PM   #4
Just call me Andrew
Give one good reason why you need 4 panels
Andrew
Old 06-06-2010, 01:14 PM   #5
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
4 houses?
or
1 main panel and 1 sub in the house; 1 sub for (or in) the outbuilding; and 1 for Christmas lights
Old 06-06-2010, 01:24 PM   #6
the Musigician
I just need a sub-panel because of all the new regs to pass code. Hey nap, you got a Seimens panel laying around? Want to take a drive today? LOL I only found one square-d on CL that got a reply. Still working on that possibility.
DM
Old 06-06-2010, 01:27 PM   #7
the Musigician
Originally Posted by nap View Post
4 houses?
or
Nononono, this is ScubaDave we're talking about, right????
It's 1 main panel for the house, and 3 subs for the Christmas lights!
DM
Old 06-06-2010, 01:37 PM   #8
4 houses?
or
Nap has it
Main 200a panel was full, so a 100a panel beside it
Then a 60a sub in the pool cabana
And a 100a sub (200a panel) in the great room
Great room panel will supply my Christmas display - 20 20a outside circuits
It will also supply the bar area - being setup as a complete kitchen w/50a stove
50a hot tub, (2) 50a stoves, 30a 240v WH, 30a 240v steam shower
30a 240v 24k BTU AC, 30a 240v dryer
That's 14 breaker spaces right there
Multiple Panel Question theatretch85 Electrical 7 09-29-2016 07:15 PM
100 -> 200 amp panel upgrade questions philipjcaputo Electrical 1 10-30-2009 03:35 AM
Replacing 2 Sub Panels with 1 Larger Panel GuitarJack Electrical 7 08-25-2009 08:43 PM
Replacement Meter Panel leonard_voet Electrical 19 04-09-2008 10:27 AM
Installing new (service?) breaker panel and generator panel Nhrafan Electrical 6 04-01-2008 03:03 PM
