Mixing Gauges Of Heater Wire? - Electrical - DIY Chatroom Home Improvement Forum
Old 04-27-2010, 02:23 PM   #1
Rewards Points: 133
Mixing gauges of heater wire?
My electrician roughed in a heater feed wire to the area of my new office space. It looked red and I assumed it was 12 gauge. It is connected to 2 15 amp breakers on its own circuit on the main panel....just like all the other heater circuits in the house. However, it is pink and it is 14 gauge.
I know this is ok by the code (British Columbia) or he wouldn't have done it.
I plan to put 1500 W of heaters in the office space, but I went ahead and wired it with regular red 12 gauge wire, including the wire to the thermostat.
Is that a problem when I connect my wiring to the 14 gauge feeder?
Hossenfeffer is offline   Reply With Quote
Old 04-27-2010, 03:12 PM   #2
Electrician
Rewards Points: 910
No problem as long as you keep the 15A breaker. There is situations when you can put #14 onto a 20A breaker for heat but to save you the confusion I will not go into it. Keept it a 15A breaker, make a note by the panel or in the junction box that there is #14 mixed in with it and not to bump the breaker size up.
darren is offline   Reply With Quote
Old 04-27-2010, 04:29 PM   #3
Rewards Points: 133
Thanks, Darren.
I was thinking just along those lines after reading a bit more in DIY posts about heaters around the web......eg. ok to use beefier wire as done to avoid voltage drops...just never use lighter wire.....and mixing seems not a problem, as you confirmed, as long as the one pays attention to the breaker rating.
And I guess if anyone should know about wiring up for heat it would be a Pegger.
oh my bad. Ok ok, it is pouring here on the Wet Coast.
Pilot on Williams millivolt wall heater goes out every 8 to 16 hours wornways HVAC 30 06-22-2011 03:29 PM
Low Voltage Wire Shorting Rdakota06 Electrical 3 07-22-2009 01:15 PM
Real Basic Electrical question re: neutral wire hellothere123 Electrical 22 07-21-2009 06:07 PM
how to wire a low voltage thermostat to a baseboard heater db3iii HVAC 4 06-05-2009 08:03 PM
Neutral Wire? 4x15mph Electrical 8 11-24-2008 01:00 PM
