Mis -wired Lcd Tv - Electrical - DIY Chatroom Home Improvement Forum
Old 03-31-2010, 10:01 PM   #1
mis -wired lcd tv
if you accidently wire up a 12v lcd the wrong way i.e.positive to negative
does it cause massive damage
especially when it was wired with 24v dc
popofski is offline   Reply With Quote
Old 03-31-2010, 10:17 PM   #2
Rewards Points: 2,800
Yes you can cause damage unless there is specific built in circuit protection for just this eventuality.
Stick to your lawn watering schedule until it really starts to pour. After the storm you have only the same number of rest days you always had and then you need to start watering again.
Old 03-31-2010, 10:26 PM   #3
Putting 24v thru something designed for 12v can burn it out
Tags
doesn't work =dead , have i killed my tv?
One thermostat for two baseboard heaters wired this way GabrielB Electrical 4 12-23-2009 07:40 PM
Newly wired doorbell not working GoPens Electrical 8 08-15-2009 08:58 AM
Motion switch wired to two circuits Sibkuz Electrical 2 04-22-2009 07:31 PM
light switches wired in series -- why? magnolia Electrical 2 05-11-2008 11:16 AM
Is this outlet wired correctly? NotSoHandyDan Electrical 14 04-11-2008 08:56 PM
