Mini Breakers A Bad Choice? - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 08-10-2010, 09:49 AM   #16
Licensed electrician
Rewards Points: 3,654
If the panel is not listed for use with tandems it does not matter that you would still be under the circuit limit for the panel.
If you still have two spots available, just switch it to a single pole breaker.
Old 08-18-2010, 01:14 PM   #17
Rewards Points: 91
mini breakers a bad choice?
I called Eaton, who now owns the Westinghouse and Cutler Hammer brands, and confirmed that the '2020' in the label indicates that tandems can't be used.
debiasio is offline   Reply With Quote
Old 08-18-2010, 02:27 PM   #18
Thanks for the confirmation.
Can I get AFCI breakers for my panel? BlueBSH Electrical 21 08-04-2010 07:07 AM
Total of Circuit Breakers xraydido Electrical 19 05-13-2010 01:08 PM
Honeywell mini zone and generator power daddyrabbit HVAC 2 02-12-2010 10:09 PM
Can I install tandem breakers to stop my breakers from tripping? sofakng Electrical 1 04-29-2009 01:44 PM
Help! Circuit breakers in trouble Circuit breakers Electrical 9 12-22-2008 12:58 PM
