Metal Sheathing - Electrical - DIY Chatroom Home Improvement Forum
Old 10-26-2014, 08:22 AM   #1
Rewards Points: 141
metal sheathing
A section of wiring is traveling through a wall that is shared with another property. Can I run just that section of the wiring through a metal casing tube. Can I purchase empty metal casing and run the wire through it?
DiegoJames is offline   Reply With Quote
Old 10-26-2014, 10:06 AM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 96
Yes you can buy flex metal conduit -- Greenfield. Or use type AC or MC metal sheath cable. (Commonly called BX.)
My electrical answers are based on 2014 NEC, you may have local amendments.
Old 10-26-2014, 12:41 PM   #3
Rewards Points: 3,396
What is the wiring for?
Low or High voltage?
I'm not knowing of boca or whatever is out there, but what is the problem with wiring in a shared wall?
If it is a problem, how would chasing it thru greenfield correct it.
"IF" it where an issue, sounds that it should be relocated.
ritelec is offline   Reply With Quote
Metal Edging and Odd Connection Point on Wall cloves Tiling, ceramics, marble 4 06-21-2014 05:34 PM
Microwave with metal rack? miamicuse Appliances 15 05-31-2014 09:49 AM
Why can't you connect Ground/Neutral bus bars on a sub secutanudu Electrical 42 11-07-2012 02:33 PM
Replacing metal box caused issues rivers001 Electrical 28 03-07-2011 01:21 AM
New roof and Sheathing - Install new fascia before or after? hartkem Roofing/Siding 2 06-01-2009 01:12 PM
