Metal Plated Light Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 03-06-2010, 07:09 PM   #1
metal plated light switch
Recently swapped out 3 way light switch for metal plated switches. To test that I didn't pinch/damage any of the wires while installing them and make the switch live, I used a neon screwdriver voltage tester. Whilst touching the tester against the switch the neon bulb flickered briefly, retried nothing went to another switch same thing happend. The switches are earthed and are working and the tester worked fine locating the live wires in the circuit. Do i have anything to worry about.
The Vital spark is offline   Reply With Quote
Old 03-07-2010, 09:51 AM   #2
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
you might just be reading power from the power wire going to switch,metal cover could just be magnifying this enough for your meter to pick it up
plummen is offline   Reply With Quote
Old 03-07-2010, 12:24 PM   #3
Electrical Contractor
jbfan's Avatar
Rewards Points: 946
Try the same test with the plastic plate.
The screws of the plate are grounded, it the switch is grounded.
If the switch is not grounded, I would not use a metal plate.
Yes I am a pirate, two hundred years too late
The cannons don't thunder, there's nothing to plunder
I'm an over-forty victim of fate.
Please Help! 3 way switches controling 2 light fxtures. HelloMotto Electrical 52 11-05-2014 04:28 PM
Motion Light tripping GFCI? Jonobp Electrical 5 09-07-2009 07:52 PM
Confused by switch w/indicator light install... WaldenL Electrical 7 08-29-2009 09:02 AM
Tracing light switch to an outlet allanet Electrical 13 04-03-2009 08:44 AM
no power going to the light switch baseballfan Electrical 18 09-08-2008 05:35 PM
