Meets NEC? - Electrical - DIY Chatroom Home Improvement Forum
Old 05-26-2020, 07:56 PM   #1
Rewards Points: 64
Meets NEC?
I added an outlet box and an additional light fixture in my attic. I already know that I should have made the last conduit longer so I could staple it to the rafters <6" from each box. Soon I will relocate it to allow for the staples.
Apart from that, is there an NEC issue with mounting electrical this close to roof decking? I had first mounted the boxes on lower framing, until knocking the bulb out with my head.
The attic and I are in Georgia, USA.
steves7839 is offline   Reply With Quote
Old 05-26-2020, 09:24 PM   #2
surferdude2's Avatar
Rewards Points: 858
Re: Meets NEC?
I see no problem with NEC once you get the cable supported and all boxes buttoned up.
I used a fixture like you but not a keyless one. I chose one with a receptacle and a pull chain switch on it. Then I ran mason's line from the pull chain to the crawl space opening 20' away... making a red-neck wall switch.
There's more than one way to skin a Cat. ~ C.L. Best 1878 - 1951
surferdude2 is offline   Reply With Quote
Old 05-27-2020, 04:40 AM   #3
Naildriver
chandler48's Avatar
Rewards Points: 4,228
Re: Meets NEC?
The way I am seeing it you have the light switch controlled, and so is the receptacle.
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is online now   Reply With Quote
Old 05-27-2020, 09:52 AM   #4
Rewards Points: 58
No problem since you will not be up there using the receptacle in the dark.
Wiredindallas is offline   Reply With Quote
Old 05-27-2020, 10:17 AM   #5
Rewards Points: 64
Re: Meets NEC?
Correct. These are add-ons wired in series after the switched attic light bulb over the drop-down attic stair.
Old 05-27-2020, 04:18 PM   #6
Naildriver
chandler48's Avatar
Re: Meets NEC?
You dang well got me on that one
Larry......
Tags
attic , conduit , rafter
