MC Cable From Plastic Box? - Electrical - DIY Chatroom Home Improvement Forum
Old 01-14-2020, 09:55 AM   #1
Rewards Points: 34
MC Cable from Plastic Box?
I'll cut out the context to keep this brief...
Can a person use a metal handybox cover with a 1/2 knock out to run MC cable out the front of a plastic box?
https://www.homedepot.com/p/Steel-Ci...-202590845-_-N
clineco is offline   Reply With Quote
Old 01-14-2020, 11:05 AM   #2
Master Electrician
Rewards Points: 5,438
Re: MC Cable from Plastic Box?
Size:  31.3 KBUse a box extender and a blank cover.
brric is offline   Reply With Quote
Old 01-16-2020, 12:47 AM   #3
Disrespectful to dirt
Fishbulb28's Avatar
Rewards Points: 2,148
Yes, either the cover or the extension ring would be acceptable.
Both the cover and the cable sheath need to be appropriately grounded. If using the extension ring you can use a simple grounding clip and pigtail it to the circuit's equipment grounding conductor. The clip won't fit the beveled edge of a handy box cover so you would instead need to use a bonding bushing on the MC fitting. 1/2" bonding bushings won't be at the home improvement stores so you'll need to order it over the Internet or visit a real electrical supply house.
Fishbulb28 is offline   Reply With Quote
Tags
box , handybox , mc cable , plastic
