Make 2 Cores Cable Out Of 4 Cores - Electrical - DIY Chatroom Home Improvement Forum
Old 11-23-2009, 08:10 PM   #1
Make 2 Cores cable out of 4 cores
I have asked this question in the Electrican forum but were told to repost this here ... Quick Question ... pls help ....
I am having a 4 cores cable 1.5 mm2 & Earth (ie 5 Cores) can I bundle 2 cable each to carry larger current
Obviously 1.5mm2 + 1.5 mm2 will be 3 mm2 :-) and I'll calculate the current accordingly
My question is from a Standard wiring perspective, is this legal ?
Thank you in advance
Happy1 is offline   Reply With Quote
Old 11-23-2009, 08:15 PM   #2
Where are you located ? ......Australia ?
This is your 1st post on this forum, so I'm not sure where you were
Not sure what you are talking about as far as core cables
What are you running power to & from ?
Old 11-23-2009, 08:24 PM   #3
Hi Scuba
Thank you for asking ...
I am from Australia
Normal Power cable has 3 cores (Active = Brown) (Neutral = Blue) (Earth = green)
In my case I have 5 cores (Brown, Blue, White, Black and Earth = Green)
Each core is 1.5 mm2 (which is about 20 Amp Max), I wonder if I can Bundle two of 1.5mm2 to make it carry larger current - Obviously from a scientific point of view, it would :-) but ... Is this legal ?
Old 11-23-2009, 08:27 PM   #4
Here (US) - as far as I know - we are not allowed to parallel conductors to carry more power
At least not in a standard residential setting
Old 11-24-2009, 12:02 AM   #5
" Euro " electrician
frenchelectrican's Avatar
I just want to make it clear I allready concat one of my freind he is Aussie electrician and he say no you can NOT parallel it at all.
It is the same thing in French electrical codes we can not do that either at all.
The only way you can make it legit is change the cable to larger size if you need a 20 amp circuit you will need 4.0mm˛ cable
Merci,Marc
P.S. the only time we can parallel the conductors if they are larger than 55mm˛ ( 1/0 AWG ) and above that useally found in commercal and industrail useage but resdentail useage it is super limited.
Old 11-24-2009, 09:07 AM   #6
Super Moderator
joed's Avatar
Rewards Points: 30,866
2 x 1.5mm core does equate to 3mm core. Just by taking the area of a circle a 1.5 mm is 1.76 and a 3mm is 7.68. You would need 4 1.5 to be close to a 3mm.
Old 11-24-2009, 05:37 PM   #7
Thank you all for the replies
Look like I have to use the Brown (Active) and Blue (Neutral) and Green (Earth) and leave the other White and Black blank ... It is a waste :-)
Hi Joed ... :-) Sorry ... ISO Metrix was confusing but they r using it over here ...
The wire was 1.5 mm2 (Area) and It can carry Max of about 19 Amps - so obviously 2 of 1.5 mm2 would carry around 38 Amps plus abit more as the surface area of 2 of 1.5 mm2 is more than the 3 mm2 and this is AC
Cheers
Old 11-24-2009, 05:51 PM   #8
..............No
220/221 is offline   Reply With Quote
Old 11-24-2009, 06:24 PM   #9
Super Moderator
joed's Avatar
Cheers
We don't use that standard here. I thought the 1.5 was the diameter not the area. Ignore my previous post math.
Couldn't you use the other two wires for a separate circuit. Two small circuits instead of one large circuit.
Old 11-24-2009, 06:31 PM   #10
Cheers
ummm....No
(2) 1.5's are NOT close to 3mm
You do understand math & electricity ?
You think power only flows on the surface of the wire ??
(2) 1.5's (1.76 each) = total area of 3.52....not the 3mm you have been told you require
And that is only 46% of the 3mm core (7.68)
You have been told it's NOT code & thus not legal
Armored Cable Question jlaky2000 Electrical 17 12-01-2008 09:07 PM
Where to buy cable? bluefitness Electrical 5 12-01-2008 04:28 PM
SE cable next to coaxial cable moondog111 Electrical 6 11-12-2008 03:12 PM
Transformer Help chcustom Electrical 28 12-10-2007 10:40 PM
Coaxial Cable Question bahaisamurai Home Theater 9 08-08-2007 02:54 PM
