Major Problem! - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 12-19-2009, 08:02 AM   #16
Originally Posted by Vikeologist View Post
Should I really be this worried about those wires up there starting a fire?
I don't think anyone can answer that without seeing it. It's definitely not done the "right" way, but it's possible that it could be "safe enough" for the moment. Obviously it has been successful from whenever it was put in until today, and they haven't had cloth wire in many years.
pyper is offline   Reply With Quote
Old 12-19-2009, 08:53 AM   #17
Should I really be this worried about those wires up there starting a fire? I mean I havent slept or ate much since...yeah I know im a worry wart, but should I be this concerned?
I would make sure that the connections are not buried in insulation
Do they have wire caps on the connections ?
Or at the very least tape ?
Old 12-19-2009, 09:31 AM   #18
I wouldn't worry unless you've already started in on changing wiring someplace. Left alone it will be fine until you get an electrician involved.
I would be concerned after someone starts crawling around in the attic. Not knowing what you disturbing wire-wise under the insulation can cause problems.
Get some estimates from licensed electricians and then don't disturb anything until he's done.
Costly, probably, but the peace of mind you'll have after it's done is well worth it.
Shamus
Shamus is offline   Reply With Quote
Old 12-19-2009, 09:54 AM   #19
yes they have tape
Vikeologist is offline   Reply With Quote
