Major Problem! - Electrical - DIY Chatroom Home Improvement Forum
Old 12-18-2009, 03:00 PM   #1
Major Problem!
I am in the middle of an entire bathroom remodel. we put in a new fan, and in the process of wiring it, and wiring a new light over the vanity, we ran into a very scary surprise.
Most of the wires in the house are spliced in the attic with NO junction boxes. Wires are spliced onto other wires, and then those wires are spliced onto other wires and run to different rooms of the house.
When I shut off the breaker for the bathroom, over half of the house is dead...almost everything is on one breaker.
What should we do about this?
Vikeologist is offline   Reply With Quote
Old 12-18-2009, 03:09 PM   #2
Civil Engineer
Rewards Points: 5,246
Welcome to the world of remodeling. You should plan to bring the electrical in the house up to code, which means no hidden splices, properly sized wire, an adequate number of properly sized breakers, and installation of ground fault interrupt outlets in the bathroom (per NEC code). If you are doing the work yourself, you may want to purchase a book on electrical wiring, unless you have enough experience to plan and execute the work. If you have hired an electrical contractor, they should know exactly what to do to fix the problems.
Old 12-18-2009, 03:21 PM   #3
Where are you located ?
How big is the house.....1 floor......basement ?
How big is the Main panel - 100a ?
Any space for more breakers ?
What kind of wire...old cloth style, new plastic cased NMB.....?
Dedicated 20a run to bathroom required, GFCI protected or GFCI outlet
I'd redo some or all of the wiring & plan on putting any & all splices in boxes
Old 12-18-2009, 03:32 PM   #4
Minnesota...
1 story
yes there is a basement
100 amp
not much room for more breakers, but I would like to upgrade to 200 amp service anyways...plus the meter and wire up to the house is all ready for 200 amp service.
it is old cloth wiring...
also, all of these wires in the attic are burried under insulation.
Old 12-18-2009, 03:37 PM   #5
Buried under insulation is sort of OK
Most electricians (and people) do not like it under insulation
My main reason is you can't see it
What type of insulation....cellulose is sprayed to be fire resistant
But I have heard of it catching fire
I think I'd put a 200a panel in where I wanted it - next to the 100a
Close enough to run a new feed easily
Run new wires & outlets as needed
I do my runs to the 1st floor from the basement, less wire
Once you have enough run have the 200a powered as the Main panel
Then feed the 100a as a sub & seperate grounds & neutrals
I have a 200a with a 100a sub about 3' to the left
Have you done electric work before ?
Are you allowed to as a homeowner where you are located ?
Old 12-18-2009, 03:40 PM   #6
well my dad is doing most of it, but if I went to that extreme, I would hire an electrician, but this is going to be a lot of hours I suppose huh?
wow, this is totally puting me over budget for the bathroom project
Old 12-18-2009, 03:48 PM   #7
Yup, rewiring is a lot of work
I've been working on rewiring my house for about 6 years bit by bit
Plus I have added a lot, dormered 2nd floor is all new wire
Old 12-18-2009, 03:51 PM   #8
My house had old cloth wiring. We had the service upgraded and the electrician insisted on replacing all the wiring. He said the cloth had deterioriated to the point of being a fire hazard.
Rewiring a house is a pretty big project -- most people are probably better off getting a professional to do it.
pyper is offline   Reply With Quote
Old 12-18-2009, 04:10 PM   #9
how much would it cost? I know every area and every electrician is different, but about how long would it take for a small single story home?
Old 12-18-2009, 04:14 PM   #10
Super Moderator
joed's Avatar
Rewards Points: 23,998
Some code items that you need to comply with.
1. Bathroom receptacles must be on a circuit that only serves the bathroom. Must be 20 amp circuit. Other stuff in bathroom can be on circuit.
2. Bedroom circuits must be AFCI.
Old 12-18-2009, 05:30 PM   #11
Really not possible to estimate this over the Internet
Prices vary widely by area & the specific job
You need to get several local quotes & check references
Old 12-18-2009, 05:49 PM   #12
Call someone.
220/221 is offline   Reply With Quote
Old 12-18-2009, 09:00 PM   #13
Electrician
Rewards Points: 910
Call someone like 220/221 said and then open up your wallet.
darren is offline   Reply With Quote
Old 12-19-2009, 06:09 AM   #14
Ours was a small single story home. I think it cost $1500 and took three days, but he did the job for the original price that he quoted prior to realizing that he was going to be re-wiring so much more. Originally we had brought him in to add a few circuits, clean up some old problems, and wire two rooms that were gutted. He ended up re-wiring the other three rooms.
Old 12-19-2009, 06:30 AM   #15
Well I will definately call a couple of electricians to get an estimate....but im scared to death..
Should I really be this worried about those wires up there starting a fire? I mean I havent slept or ate much since...yeah I know im a worry wart, but should I be this concerned?
