Main Power Goes Out When Dryer And TV Are Both On - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 11-30-2009, 06:37 PM   #16
readydave8
Rewards Points: 16
Originally Posted by Yoyizit View Post
My robot lady
http://www.oddcast.com/demos/tts/tts...le.php?clients
translates this to
Call the power company to initially treat with their side first
Nahe genug. . .
not a power company issue if flipping breaker of and then back on makes it work.
readydave8 is offline   Reply With Quote
Old 11-30-2009, 07:14 PM   #17
" Euro " electrician
frenchelectrican's Avatar
Originally Posted by will0527 View Post
The whole house goes out. The manufacturer is GE. I'll see if I can post a pic later.
The keyword is the whole house goes out so it mean everything just stop functioning.
That my first thing I will say POCO side over 65% of the time the cupit useally on their side useally more than interal side.
And what most POCO do not charge for the trip to come out and inspect their system { most common cupirt is bad bug or crimp going break apart }
Merci,Marc
Old 12-02-2009, 07:03 PM   #18
readydave8
Rewards Points: 16
Merci,Marc
post#5 he says he has to flip the main breaker off and then on to get power back. this indicates it not to be a poco problem. even if they don't charge to come out and check they had the cost of nusiance calls into the cost of electricity. its very similiar to how i charge--I'm going to go back on some jobs under warrantee even though its almost definetly not covered (to change or tighten bulbs in a light fixture that I hung, for example. Probably has happened 20 times). This goes into my thinking when I set my prices.
If turning the main breaker off and back on restores power, it is not a poco problem.
Old 12-02-2009, 07:35 PM   #19
Thumbs up
Appelez la compagnie d'électricité d'abord pour traiter avec leur côté d'abord
Call the Power Company first to deal with their side first.
Mais peu etre que le problem es dans la cote du client?
(The translation is, hopefully, more accurate than the original)!
But it's possible that the problem is on the customer's side. (i.e.; defective main breaker) In our town (New York City) There's a penalty for calling the power Co. when the problem is in the customer's equipment or wiring. Here, the PoCo is the last on the list to be called. When you checked out everything else, and are 250% certain that the source of the problem is on the side of the utility! (No matter what) Don't Drink and Drive, Ever!!!
spark plug is offline   Reply With Quote
Old 12-02-2009, 07:42 PM   #20
Question
I agree with your assessment. As a matter of fact, before I call the PoCo I use Three different testers + my bare hands to be sure that the main lug does not carry electricity (maybe a little overdone) before I call the Utility.
Old 12-02-2009, 07:50 PM   #21
Est-ce que vous êtes sérieux de vos mains sur le fil électrique ? ?
Merci, Marc
Old 12-02-2009, 08:10 PM   #22
Red face
Merci, Marc
Non. ne pas toujour. Seullement une foie!
(I always give the disclaimer first.) No. Not always. (not all the time) Only did that once. In other words. What you're saying Monsieur French electr. that it's not worth getting yourself killed rather than looking bad in the eyes of the Electric Co. I'll admit it was an exaggeration. But I will always make absolutely certain that the problem is on the side of the power Co. I once had a service call in an apartment building where there was no reading on the line side of the main switch. When I double checked I realized that the power was really coming from another building in the same complex. There I found a blown 400a. fuse. Even if the fault is in the PoCo lines, they will always ask you to "Bridge" the service before they come out, if it's only on one leg.
Please look at this dryer vent installation Andy Griffith Appliances 6 08-31-2009 12:39 PM
Update: Power on several circuits comes and goes all at once, never trips breaker Michael H Electrical 9 07-03-2009 10:12 PM
Dryer vent ponch37300 General DIY Discussions 10 01-21-2009 04:26 PM
Dryer Pony Problem. Hobb3s Electrical 17 09-30-2008 08:16 PM
Dryer Grounding??? Traci_howdyadothat Electrical 7 05-27-2008 01:14 PM
