Main Panel Without Main Disconnect - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 01-01-2010, 10:53 PM   #16
Something just seems wrong with this whole thing! OP are you able to provide pics of the panel and also your meter box?
Paelectrican is offline   Reply With Quote
Old 01-02-2010, 08:12 AM   #17
left side is the main panel. right side is the sub panel. the main panel is Murray LC4040L1200.
ninghai is offline   Reply With Quote
Old 01-02-2010, 08:15 AM   #18
Look outside by the meter. Can you take a picture of the meter socket?
jerryh3 is offline   Reply With Quote
Old 01-02-2010, 08:17 AM   #19
Note the service lines are connected directly to the hot bus without a disconnect. The first two breakers on the left side supply the sub panel.
Old 01-02-2010, 08:20 AM   #20
meter box outside. it does have a 200A main breaker here.
Old 01-02-2010, 08:20 AM   #21
Gotta love wirenuts in a new construction panel.
Old 01-02-2010, 08:22 AM   #22
There you go. There's your disconnect. Can you take some close pics of the neutral and ground bars in the main panel.
Old 01-02-2010, 08:28 AM   #23
what are you looking for specifically?
yes, there are a couple of wire nuts in there. but the inspector didn't say anything so i assume it was OK. not fantastic but OK.
just to clear the question. the entire house is wired by the same electrician and it passed the inspection already.
Old 01-02-2010, 08:29 AM   #24
CodeEnforcer
HIVOLT's Avatar
Rewards Points: 99
Is this a single family dwelling or condo?
HIVOLT is offline   Reply With Quote
Old 01-02-2010, 08:32 AM   #25
CodeEnforcer
HIVOLT's Avatar
Rewards Points: 99
This is perfectly legal in MA.
Old 01-02-2010, 08:34 AM   #26
single family.
Old 01-02-2010, 08:35 AM   #27
Electrical Contractor
wirenut1110's Avatar
Rewards Points: 510
Send a message via AIM to wirenut1110
It looks like the wirenutted connections are neutral extensions of the AFCI neutral.
Not sure why the white conductors not re-identified as ungrounded wasn't caught.
wirenut1110 is offline   Reply With Quote
Old 01-02-2010, 08:37 AM   #28
Just wanted to see if all of the grounds and neutrals were separated at the main and if bonding screw was removed. Yes, not pretty, but it's legal.
Old 01-02-2010, 08:46 AM   #29
CodeEnforcer
HIVOLT's Avatar
Rewards Points: 99
Can you take a closer picture of the red wirenut in side the panel?
Old 01-02-2010, 08:52 AM   #30
You mean the one with multiples wires nutted together? At least that's what it looks like. But hey, it was passed by an inspector so it must be safe. Hope they're on different phases...
Main Panel / Service Upgrades gbe Electrical 12 11-06-2009 11:20 PM
Subpanel for now, convert to 2nd main panel later? abmiller67 Electrical 2 08-27-2009 01:44 PM
Melted Service Entrance Wire in Panel theatretch85 Electrical 13 08-22-2008 10:37 AM
Determining Main Panel Load with Subpanel added Randell Tarin Electrical 2 04-11-2008 01:21 PM
turn main panel into a sub panel? tikicarver Electrical 2 01-24-2008 07:37 AM
