Main Panel As J-box? - Electrical - DIY Chatroom Home Improvement Forum
Old 05-25-2010, 07:30 PM   #1
main panel as j-box?
Can you consider your main panel as a j-box?
joseph2293 is offline   Reply With Quote
Old 05-25-2010, 07:48 PM   #2
Licensed electrician
Rewards Points: 3,652
If you could explain your situation better a more correct answer can be given.
Old 05-25-2010, 08:18 PM   #3
Sounded pretty self explanatory...but i need to wire nut some wires together in my main panel can i do it or do i have to wire nut them together outside the panel?
Old 05-25-2010, 08:54 PM   #4
" Euro " electrician
frenchelectrican's Avatar
Yes and No depending on what it have to be done.
If feed thru the answer is no but to extend the conductor to reach the breaker yeah it is legit but it depending on how big the load centre you have there.
Merci,Marc
Old 05-25-2010, 09:34 PM   #5
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 2,006
Not at all, at least the way it was asked. It almost seemed intentionally vague.
French gave you the perfect answer after the follow up information was given.
The Following User Says Thank You to Speedy Petey For This Useful Post:
frenchelectrican (05-26-2010)
Old 05-25-2010, 10:11 PM   #6
Or you could have just answered it the way french did and not make a scene...just my .02 cents
Old 05-25-2010, 10:20 PM   #7
The more information provided the better & more direct answer to the specific question
Its very common for people to ask for more info rather then try to think of everything you might possibly do
The Following 2 Users Say Thank You to Scuba_Dave For This Useful Post:
frenchelectrican (05-26-2010), Leah Frances (05-26-2010)
Old 05-26-2010, 05:26 AM   #8
Old 05-26-2010, 08:22 AM   #9
Sparkaholic
Rewards Points: 150
Send a message via Yahoo to sparks1up
No!
There as simple and vague as your question!
Answers based on the mood I am in when you ask!
sparks1up is offline   Reply With Quote
Old 05-26-2010, 08:28 PM   #10
Ok lets just have everyone settle down a minute...thanks french for the reply
The Following User Says Thank You to joseph2293 For This Useful Post:
Old 05-27-2010, 01:03 AM   #11
liscenced electrician
Rewards Points: 540
i have to agree with everyone else. Your attitude seems very cocky. Not a good way to get help. And no, you can not use your panel as a junction box.
jimmy21 is offline   Reply With Quote
Old 05-27-2010, 02:53 AM   #12
Sure no problem at all and that answer I provide to you that is pretty much International rules anyway. That answer I gave you that rules that used in North America and it is the excat same rules in France so that is a quick automatic answer for me.
Merci,Marc
Old 05-27-2010, 06:17 AM   #13
But you CAN make splices in a panel.
Old 05-28-2010, 02:44 PM   #14
Totally screwed together
Another situation would be if you were installing a new service panel, and wanted to use your old service panel as a J box.
See, now there are 3 different variations on what your question could have ment!
xxPaulCPxx is offline   Reply With Quote
Old 05-28-2010, 11:50 PM   #15
Okay, so is the situation legal? Remove all the breakers and ground/neutral bars and then wire nut the connections of even install some kind of connectors to attach the wires to, but insulated from the metal box.
Mike in Arkansas is offline   Reply With Quote
Multiple Panel Question theatretch85 Electrical 7 09-29-2016 07:15 PM
Main panel or sub panel? tbeaulieu Electrical 5 04-07-2010 11:58 AM
easy question - PVC conduit connection to main panel tpagel Electrical 14 07-17-2009 06:50 PM
gfci in main feeding sub panel problem scott2332 Electrical 12 02-25-2009 11:17 PM
main lug vs main breaker for sub panel diyll Electrical 1 01-17-2008 08:18 PM
