Main Panel Concern - Electrical - DIY Chatroom Home Improvement Forum
Old 11-05-2010, 11:37 PM   #1
Question
main panel concern
I have a main panel concern/question:
There are three circuits in the box that have the white (neutral) and the ground (bare ground) tied together with wire nuts.
This seems incorrect to me...I know they eventually terminate at the neutral/ground bus, but should they be joined before that?
Thanks in advance!
tbarnett is offline   Reply With Quote
Old 11-06-2010, 06:19 AM   #2
Rewards Points: 2,800
Electrically it makes no difference in the main panel (panel with the first main disconnect switch) but technically the ground wires and the neutral wires should individually continue all the way to the neutral/ground bus (or terminal strip).
If neither will reach, leave one connected to the existing pigtail to the bus and wire nut on a second pigtail for the other.
Incidentally, each neutral must have its own hole and screw on the bus.
Stick to your lawn watering schedule until it really starts to pour. After the storm you have only the same number of rest days you always had and then you need to start watering again.
Old 11-06-2010, 06:34 AM   #3
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 2,006
They should absolutely NOT be spliced together as they are. If they needed to be extended they should be done individually.
The Following User Says Thank You to Speedy Petey For This Useful Post:
J. V. (11-06-2010)
Old 11-06-2010, 08:28 AM   #4
Are you sure they are 3 separate circuits ?
Are there any hots spliced together that go to the same breaker ?
Old 11-06-2010, 08:44 AM   #5
Just call me Andrew
Rewards Points: 1,032
Where are you located?
Andrew
secutanudu is offline   Reply With Quote
Main panel or sub panel? tbeaulieu Electrical 5 04-07-2010 11:58 AM
main panel distribution concern to out building coupe33 Electrical 3 11-07-2009 01:45 PM
gfci in main feeding sub panel problem scott2332 Electrical 12 02-25-2009 11:17 PM
Replace main panel? And lots of other ?s Bcoleman6 Electrical 13 01-22-2008 09:40 AM
main lug vs main breaker for sub panel diyll Electrical 1 01-17-2008 08:18 PM
