Main Panel Bus Bar Question - Electrical - DIY Chatroom Home Improvement Forum
Old 01-25-2010, 02:35 PM   #1
main panel bus bar question
I understand that for the main point of entry panel, the neutral and ground are combined on the same buss bar. Sub-panels, on the other hand have the neutral and ground wires on separated bus bars and a new ground needs to be installed for the sub-panel. Just wanted to confirm this is correct, as I replaced a breaker on my main POE panel and saw the ground and neutral combined on the buss bar.
Thanks, JC
205bhamjim is offline   Reply With Quote
Old 01-25-2010, 02:53 PM   #2
Thanks, JC
At the 1st disconnect the grounds & neutrals can share & are bonded to the case
This is not always the Main panel
Subs they are kept seperate & neutral bar is isolated from the case
Subs need 4 wires run from the main panel
A sub in a detached building must also have ground rods
Old House Rewire finnimus Electrical 15 05-13-2011 10:39 PM
Garage Wiring issues jimmyfloyd Electrical 20 06-08-2009 02:57 PM
Extending Old Main Circuit Panel lkpowell Electrical 4 10-23-2008 02:15 PM
Replace main panel? And lots of other ?s Bcoleman6 Electrical 13 01-22-2008 09:40 AM
main lug vs main breaker for sub panel diyll Electrical 1 01-17-2008 08:18 PM
