Main Elec Service Panel Location - Electrical - DIY Chatroom Home Improvement Forum
Old 12-16-2009, 11:44 AM   #1
Rewards Points: 270
Main elec service panel location
As I understand it, electrical panels cannot be located in clothes closets, but can they be located in an enclosure or room all their own, with nothing stored within? I have an existing panel box in the middle of a remodel I am contemplating. I want to create an electrical closet for it. That is permissable, correct? As long as I have clearances to work in front of it?
Thanks in advance
tpagel is offline   Reply With Quote
Old 12-16-2009, 02:21 PM   #2
You need 30" width, 36" in front of the panel
That would be a pretty big enclosure....and nothing can be in it
Old 12-16-2009, 02:53 PM   #3
Rewards Points: 270
I have the room in width and depth, but this would be an attic renovation and the sidewalls, where the gabled roof hits the long walls, are only 4' high, so I have height problem apparently? The top of the main panel is already only 4' off the floor and there is no way for me to have over 6' in walk-up clearance in front. Maybe talk to the code official and see if he is OK with it? Do they normally make you move the main service to the whole house in a case like this?
Old 12-16-2009, 04:16 PM   #4
Rewards Points: 266
110.26 (E) Exception: In existing dwelling units, service equipment
or panelboards that do not exceed 200 amperes shall be
permitted in spaces where the headroom is less than 2.0 m
(6 1/2 ft)
I think that a nice cabinet door or something of that sort that is easily removable would look nicer than a room for the panel.
junkcollector is offline   Reply With Quote
Old 12-16-2009, 04:40 PM   #5
Rewards Points: 270
Thank you, junk collector! As always, I appreciate everybody's efforts at my education.
Old 05-02-2010, 09:51 AM   #6
regarding the 30" clearance, i am finishing my basement and want to box the panel in for a finished look. panel is located in a corner. 36" front clearance is no problem. due to the crookedness of the poured foundation walls, the finished wall is floating about 6" off the wall near the panel. in other words, the panel is recessed. the stud opening at the panel is about 18" wide but the door can still be opened over 90 degrees. my plan is to put a cabinet door or something similar on the finished wall and leave the area behind it unfinished. there is space to remove the face of the panel to add/replace breakers.
is this kosher? or do i need 30" clearance across the face of the panel, such that i would need to build a 30" wide recess in the new wall?
itsnotrequired is offline   Reply With Quote
Old 05-02-2010, 03:02 PM   #7
Master Electrician
Rewards Points: 5,084
30" or more a corner is compliant.
brric is offline   Reply With Quote
Old 05-02-2010, 03:05 PM   #8
Master Electrician
Where would I find the requirement that nothing be inside the enclosure?
Multiple Panel Question theatretch85 Electrical 7 09-29-2016 07:15 PM
grounding of main panel and sub panel in older house linkysys Electrical 2 10-01-2009 04:34 PM
Replacing 2 Sub Panels with 1 Larger Panel GuitarJack Electrical 7 08-25-2009 08:43 PM
Upgrading to a 200 amp main service panel edmart2 Electrical 3 05-28-2009 06:57 PM
Replace main panel or use subpanel? MasterofNone Electrical 8 02-12-2008 12:24 AM
