DIY Chatroom Home Improvement Forum (https://www.diychatroom.com/)
-   Electrical (https://www.diychatroom.com/f18/)
-   -   Main disconnect box before service panel (https://www.diychatroom.com/f18/main-disconnect-box-before-service-panel-16571/)
Cellomangler 02-03-2008 10:45 PM
I am installing a new service panel in a small building. I have the masthead, meter box and temporary service available outside the wall. I'm going to go straight through a brick & cinder block wall and put in a service panel. I'll have a licensed electrician do the high voltage hookup. Question is.. I'd like to put a separate main disconnect, like a lockable double throw switch, before my service panel, which, of course, will have it's own main disconnect. I want to do this so I can totally disconnect power and work on the service box without having any hot wires near me. It would also be nice if the disconnect box had a single outlet that I could use for temp power prior to the disconnect. Is anything like this possible ? Thanks..
nap 02-03-2008 10:52 PM
You can do the disconnect. This will become your main service disconnect and the ground/neutral bond and the GEC will all be in this disconnect.
You cannot install a recep prior to the disconnect.
goose134 02-04-2008 12:14 AM
As for the receptacle, use your neighbors. How often will you need to do this anyhow?
Cellomangler 02-04-2008 01:26 AM
"As for the receptacle, use your neighbors. How often will you need to do this anyhow?"
True... I'm mainly concerned about the construction phase. I know I could just keep the temp power outside at the meter until after I've totally wired my small building and installed the service panel. But I figured it would be nice to use a few outlets in progress but also be able to totally safeguard myself when I needed to work in the service panel.
"You cannot install a recep prior to the disconnect."
So.. when they connect from my masthead/meter to my inside disconnect box (and then to the service panel) they must eliminate the temporary outdoor receptacles that are below my meter ? Or can I have them leave that up for a while ? Thanks...
handyman78 02-04-2008 08:43 AM
I saw a small panel in Lowes the other day for just the purpose of temporary power such as construction. I think it was GE or Siemens. It had breakers and a GFCI outlet or two. In any case, considering having outlets downstream from your meter and main disconnect will still need breakers appropriate for the load of those outlets.
Powered by vBulletin® Version 3.8.8
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
