Main Breaker Shut-off Vs. External Service Shut-off - Electrical - DIY Chatroom Home Improvement Forum
Old 05-08-2010, 03:39 PM   #1
Rewards Points: 356
Question
Main breaker shut-off vs. External service shut-off
I have an older house where there is an outside main service shut-off. Is there any reason that I cannot use this eternal service shut-off vs. the main breaker panel shut-off?
tripower is offline   Reply With Quote
Old 05-08-2010, 06:11 PM   #2
Inspector/Instructor
codeone's Avatar
No no reason.
codeone is offline   Reply With Quote
Old 05-08-2010, 06:48 PM   #3
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 528
I like having an external shutoff (indoors though! Outside one is too inviting to pranksters) that way if I need to do any work on the panel I can cut power to it, completely. It's a nicer feeling working in there knowing there is no power whatsoever going to the panel.
Old 05-08-2010, 06:51 PM   #4
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 1,760
If your main breaker box is over 15' from your meter, you are required to have a shut off next to the meter, here.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 05-08-2010, 07:00 PM   #5
Sparkaholic
Rewards Points: 150
Send a message via Yahoo to sparks1up
How can it be external if it is inside?
sparks1up is offline   Reply With Quote
Old 05-08-2010, 07:04 PM   #6
Wire Chewer
Rewards Points: 528
well I meant like one of those cutoffs that are not part of the electrical panel.
http://www.homedepot.ca/webapp/wcs/s...k=P_PartNumber
Old 05-09-2010, 03:31 PM   #7
Rewards Points: 356
Exclamation
That's exactly what I am saying.
Old 05-09-2010, 03:40 PM   #8
Electrician
Rewards Points: 910
In a typical panel there is a barrier between the breakers and the service entrance cables. As long as you turn the main breaker off and that barrier stays in place you are fairly safe to work in the panel.
But I can't argue to much because turing power off to the whole breaker is much safer.
darren is offline   Reply With Quote
Old 05-09-2010, 08:31 PM   #9
Just call me Andrew
Rewards Points: 1,032
If and when I upgrade my panel, I plan to do this same thing. In this scenario (main shutoff right next to your panel), can your neutral and ground bars be connected in the panel, or must it be treated like a subpanel?
Andrew
secutanudu is offline   Reply With Quote
Old 05-09-2010, 08:45 PM   #10
Wire Chewer
Rewards Points: 528
I think it's treated as a sub. I'd have to check mine, but I'm pretty sure I recall seeing bondage (I like using that word lol) in the cutoff and not in the panel. I have a 100 amp shutoff and 100 amp panel. Eventually I will upgrade my 100 amp panel myself to 200, as I can use the shut off to cut power completely. The shutoff has a fuse, so it will still be a 100 amp service. then when I have the money I can do a real upgrade, and I will buy a shutoff. They are expensive, but I think it's worth it.
That and it looks cool, giant box with huge lever on it. I like the feeling of throwing big switches like that.
Old 05-09-2010, 08:46 PM   #11
Licensed electrician
Rewards Points: 3,654
The first means of disconnect would be treated as the service. Anything downstream would be wired as a subpanel with the neutrals isolated from the grounds.
Darren, in the US we do not have the barriers around the incoming lugs like your panels. I do like that idea tho.
Main box feeding 220v and 110v brearker box off a 50am breaker? uvamosk Electrical 30 10-14-2009 10:46 PM
This doesnt seem right. JoulesWinfield Electrical 27 07-26-2009 07:40 PM
I still hear water running when I shut off the main water shut off valve jnut Plumbing 6 07-15-2009 07:46 AM
Main Breaker Trips Repeatedly kkf Electrical 7 06-18-2007 04:31 PM
Arced main lug in service panel burgeke Electrical 4 11-02-2006 11:28 AM
