Magnetic Power Switch - How Do I Install This? (Diagram And Pics Included) - Electrical - Page 3 - DIY Chatroom Home Improvement Forum
Old 01-06-2015, 08:08 PM   #31
Rewards Points: 40
I haven't talked to my electrician today but I believe this was our original circuit "set up" idea.
One circuit board for 3 rooms.
1 Key Card Switch in each room (total of 3)
1 Circuit Switch for in-window 220V/650 watt Airconditioner (total of 3 switches)
1 Circuit Switch for Lights and Outlets (total of 3 switches)
1 Circuit Switch for Outdoor Building Lights (total of 1 switch)
Grand total, 7 switches.
I want the key card switch to control the aircon circuit and indoor lights/outlet circuit. To be safe I want a relay/contactor to handle the airconditioners (so 1 for each room for a total of 3). Is it possible to have this set up as I described?
I ask because a relay is $10 each and one central circuit board is no more than $100 (total of $130). His method is to buy 3 smaller circuit boards with a relay inside of them for $80 each ($240 total). I'm trying to cut costs and simplify my life with 1 circuit board.
foxman09 is offline   Reply With Quote
Old 01-07-2015, 05:49 AM   #32
Rewards Points: 1,832
Your electrician is probably correct, AC plus lights plus what ever elese may be plugged in not to mention a hair dryer in the bathroom would require more circuits.
Jump-start is offline   Reply With Quote
Old 01-07-2015, 08:48 AM   #33
Rewards Points: 1,306
Just get a 120vac coil three 30-40A) pole contractors for $15 and use the three poles to break various circuits. No need for electronics and circuit boards.
curiousB is offline   Reply With Quote
Old 01-07-2015, 10:29 AM   #34
Rewards Points: 40
@curiousb
Are you confirming I should do what I described with the 30-40 amp contactor?
Getting power to a wireless fan switch rickjames8 Electrical 6 09-07-2014 05:46 AM
1 power source+2 3way switches+ 1 normal switch nateshirk Electrical 22 02-28-2014 07:45 AM
Confused 3 way question - with pics and diagram poorboy01 Electrical 7 11-16-2013 12:35 AM
