Low Voltage Wiring - Electrical - DIY Chatroom Home Improvement Forum
Old 06-04-2010, 10:39 AM   #1
gmhammes's Avatar
Low voltage wiring
Maybe posting this here will attract more!
I am wiring deck lights and was wonder if anybody here has some techniques or methods they use to conseal the wiring. These will be on the rail posts.
I'll try and get some picture up later today.
gmhammes is offline   Reply With Quote
Old 06-04-2010, 07:59 PM   #2
Master Electrician
install LED solar lights .
I suppose you could cut grooves the railings and hide it that way but concealing the wire isn't enough in this case...i'm assuming your using romex and you can't just install it anywhere. It would all have to be done with pvc and damp location wire as well as be on a gfci breaker.\
i missed the title where is said low voltage. i'd router out a small groove on the railing and then cut a strip that fits the groove once wiring was in place
andrew79 is offline   Reply With Quote
Old 06-04-2010, 10:22 PM   #3
I like the groove idea. That would definitely be the best for concealing the wire. Another way is to just staple the wire under railing, or you can get zipties that have a hole at the top for a screw. Then you just screw the zipties under the rail or somewhere where that they can be concealed and then run the wire and ziptie away. I've also used 5 minute epoxy before and then used clamps to let the epoxy setup, but that method is very time consuming.
altow90 is offline   Reply With Quote
low voltage wiring for niche lighting 8roty Electrical 4 01-16-2010 07:17 AM
Code requirements for low voltage wiring in conduit with 120V flyboy Electrical 9 12-24-2009 06:48 PM
wiring Dual voltage motors tiquilagold Electrical 12 07-13-2009 10:24 PM
Low Voltage Wiring Malibujim Electrical 2 05-07-2009 07:52 PM
Old Low Voltage Wiring srwjr Electrical 14 01-24-2007 07:29 PM
