DIY Chatroom Home Improvement Forum (https://www.diychatroom.com/)
-   Electrical (https://www.diychatroom.com/f18/)
-   -   Low Voltage Switches (https://www.diychatroom.com/f18/low-voltage-switches-50465/)
Mr Chips 08-07-2009 11:09 PM
Is there any reason i can't (or shouldn't) use a regular "houshold type light switch" to control 12v LED lights in my shed. Gonna throw a solar panel on the roof, a battery and controler inside, and wanted to wire up some LEDS inside. I was going to go buy a couple toggle switches, then it dawned on me that I have a bunch of 120v light switches and boxes, why not just use those. am i missing anything?
dSilanskas 08-08-2009 06:04 AM
You can use a regular switch. You don't need anything special :)
Yoyizit 08-08-2009 11:20 AM
If you do have a problem later on, it could be because the low LED current doesn't cause enough arcing to clean these 15A-rated-switch-contacts, as they are when switching normal household loads.
http://www.google.com/search?hl=en&s...&aq=f&oq=&aqi=
dSilanskas 08-08-2009 03:16 PM
You wont have an issue with it. We use them all the time don't worry about it:thumbsup:
Powered by vBulletin® Version 3.8.8
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
