Low Voltage Halogen Installation - Electrical - DIY Chatroom Home Improvement Forum
Old 07-28-2016, 08:36 AM   #1
Rewards Points: 222
low voltage halogen installation
am having a problem with a low voltage halogen lighting system, one of those systems where the fixtures hang from cables.
it came with 3 x 20w halogen MR16 bulbs (and the labels are pretty clear that that is the maximum allowed or recommended) but the light is too feeble.
So, I had the bright idea of just swapping in 3 x 35w halogens.
Much better light.
but then, a few days later, the whole system was dead.
testing (before the reset switch), it appears there is no power coming out of the transformer.
I was surprised that I could "blow" a transformer. they seem like dumb blocks of wire and metal.
Time I think to better understand transformer specs.
Here's what is written on the transformer.
Output: 12VAC 5A 60VA
(but wait a minute. about another halogen system, an electrician once told me these halgen systems have to be "under load")
so, what do the specs mean re: what load I can reasonably put on it?
and how can I trouble shoot this?
low voltage halogen installation-ikea-transformer-640x640.jpg   low voltage halogen installation-lv-halogen-lighting-640x640.jpg   low voltage halogen installation-halogen-light-system-640x640.jpg
pjstock is offline   Reply With Quote
Old 07-28-2016, 08:48 AM   #2
Rewards Points: 360
Re: low voltage halogen installation
You over amped it.
With 20 W halogens: 60W / 12V = 5A Which is what the transformer is rated for.
With 35 W halogens: 105W / 12V = 8.75A which is way above what it is rated for.
The reset button should take care of it. To get brighter light, find some 12V MR-16 LED's. They make 50W equivalents that use 7-8 watts.
herdfan is offline   Reply With Quote
The Following User Says Thank You to herdfan For This Useful Post:
pjstock (07-28-2016)
Old 07-28-2016, 09:14 AM   #3
Rewards Points: 2,728
Much better light.
You should note that 12V x 5A = 60 Watts
You then chose to connect to this supply a load of "3 x 35 W halogens" - which represents a "load" of 105 Watts.
Need I say more, concerning the 75% overload which you put on the device concerned.
So, just stop overloading your source device.
Also, I suggest that you should stop using "halogens", use LEDs and consider what it is which you are doing.
(Does anyone in their right mind set out to install "halogens" these days?)
FrodoOne is online now   Reply With Quote
Old 07-28-2016, 09:29 AM   #4
Rewards Points: 222
"(Does anyone in their right mind set out to install "halogens" these days?)"
we are now wandering WAAAY out of the technical aspects of electricity and into aesthetics but....
I just like the look of these systems and I have not seen anything new that doesn't look chunky and cheap.
Now, if I can find MR16 style LED bulbs that would fit this fixtures, I would swap them in in a blink.
and according to herdfan, I can. so, I'll get on it.
thanks for the explanations.
Old 07-28-2016, 09:42 AM   #5
Rewards Points: 222
so if I purchased three x 12W (4x3W) LEDs would that be a light enough load for this system?
does the same math apply? 3 x 12W = 36W which is less than the transformers 12V x 5A = 60 Watts?
could I add 2 extra fixtures to this rig (so 5 x 12w = 60W)?
Old 07-28-2016, 10:04 AM   #6
Rewards Points: 360
Yes. Lowe's has them.
Old 07-28-2016, 10:29 AM   #7
I do not believe that aesthetics has much to do with the original "problem" of overloading.
Be that as it may!
Since MR16 LED devices are so readily available, I cannot understand any difficulty you may have in obtaining such devices to suit your requirements "physically".
However, the existing 12 V supply may NOT be compatible with any particular MR16 LED device that you choose to use, BUT that is another story.
The Following User Says Thank You to FrodoOne For This Useful Post:
herdfan (07-28-2016)
Old 07-28-2016, 12:02 PM   #8
Rewards Points: 222
"I do not believe that aesthetics has much to do with the original "problem" of overloading"
you are absolutely right. I misunderstood your criticism of halogen.
you were only speaking about the bulbs, not the look of the cables and stuff (which I admit too is quite outdated).
in retrospect it is crazy to use halogen bulbs.
But they were in this kit that I've been storing for ... 10 years! waiting for an application. So I really just wanted to see if the whole system worked.
Now that I know that it does and that there do exist MR16 LEDs I will certainly replace them ASAP.
Peter
Old 07-28-2016, 01:56 PM   #9
Rewards Points: 360
It is a 12V AC PS. I will work fine with any 12V landscape MR-16 LED.
Old 07-28-2016, 04:04 PM   #10
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 2,006
But.....
Old 07-28-2016, 07:29 PM   #11
Rewards Points: 2,822
By "under load" we mean that if the load on some transformers is very small, the voltage is higher than the published voltage. This can burn out some kinds of electronics.
Halogen (or plain incandescent) lamps can take a small amount of overvoltage where the consequence is shorter lamp life. Using one lamp on a transformer meant for three will probably not result in significantly shorter lamp life.
Old 07-28-2016, 08:21 PM   #12
"By "under load" we mean that if the load on some transformers is very small, the voltage is higher than the published voltage. This can burn out some kinds of electronics. ".
Say what?
Colorado Sparky is offline   Reply With Quote
The Following User Says Thank You to Colorado Sparky For This Useful Post:
Druidia (07-28-2016)
Old 07-28-2016, 11:54 PM   #13
Rewards Points: 257
12V MR16 LED bulbs are much easier to find now.
I had 12V MR16 GU5.3 50W halogen track lights. I swapped them with 7W LED bulbs. I changed some of the track heads and was then able to use 120V MR16 GU10 7W LED bulbs with the new track heads.
Druidia is offline   Reply With Quote
Halogen to LED.. Halogen started smoking bmw123 Electrical 3 03-22-2014 10:19 PM
Line Voltage and Low Voltage Together? miamicuse Electrical 2 06-03-2012 08:48 PM
Resistor/Led and Basic Electricity Questions Khivar Electrical 19 04-16-2012 07:15 PM
Low voltage box question WShawn Electrical 7 08-19-2008 07:22 AM
2 - 900w tansformers on a 15A circuit? tonyBagadonuts Electrical 19 07-20-2008 08:15 PM
