Low Voltage Divider Plate For Old Work Box - Electrical - DIY Chatroom Home Improvement Forum
Old 01-17-2010, 02:48 PM   #1
Low Voltage Divider plate for old work box
Are there smaller divider plates for old work boxes? The one at link are to large and I don't see any other sizes available.
http://www.carlon.com/SC/SC_Orange6.html
rodm1 is offline   Reply With Quote
Old 01-17-2010, 03:17 PM   #2
Remodeling Contractor
not clear as to what you are looking for. The face plate that provides a finished surface? The depth of the box? The size of the divider?
Old 01-17-2010, 03:44 PM   #3
I have this box and need a Low voltage divider plate for it.
http://www.mcmelectronics.com/produc...468R-/28-17055
Old 01-17-2010, 03:48 PM   #4
" Euro " electrician
frenchelectrican's Avatar
Many big box store should have them on the shelf near the electrical boxes if not there ask one of the workers ask for " low voltage divder " they will know what you are refering to.
They don't cost very much IIRC it should be about 1 Euro or so.
Merci,Marc
Old 01-17-2010, 03:52 PM   #5
Merci,Marc
They only work in NEW work boxes. To big don't fit in OLD work boxes.
Old 01-17-2010, 03:54 PM   #6
Give me a min let me grab the correct catalog number so you can ask the big box guys for correct verison otherwise you can trim them.
Merci,Marc
Old 01-17-2010, 04:05 PM   #7
I did check it and they only listed for with super bleu boxes { thickwall plastique box } but you can trim them down and fit in the standard bleu box.
Merci,Marc
Old 01-17-2010, 05:05 PM   #8
will cutting them satisfy NEC 2008?
Thanks!
Old 01-17-2010, 07:06 PM   #9
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
from the pic, it surely looks like it was designed to accept a divider. Can you confirm that there are ribs in there where a divider would slide into?
and what brand is it. Seems like it might be proprietary design so brand might help.
never mind, I see it is a Carlon.
OT: How do High Voltage Lines work? jamiedolan Electrical 23 08-16-2009 07:48 AM
bifold alternative or how to make bi fold work Janie Carpentry 8 03-16-2009 05:45 PM
high voltage fire alarm jungboklee Electrical 3 01-26-2009 09:07 PM
Where are the "Carpenters" ???? wrldruler Carpentry 14 09-11-2008 07:37 AM
HVAC contractor ripoff! sekntonone HVAC 8 04-05-2008 07:15 AM
