DIY Chatroom Home Improvement Forum (https://www.diychatroom.com/)
-   Electrical (https://www.diychatroom.com/f18/)
-   -   looking for a gizmo! portable generator use (https://www.diychatroom.com/f18/looking-gizmo-portable-generator-use-64995/)
walt1122 02-21-2010 12:38 PM
Hi friend asked me to come take a look at his setup for supplying elelctricty during power outage. Just speaking with him he said if wasn't "tied in" or automatic. He has to start up generator after he disconnects main breaker at service panel. He is interested in being able to tell when elecric service is turned back on so he can turn off generator and go back on utility power. I said there is probably a better way to handle the this but there must be something simple that would show when power is restored to house LED at main? or something to show voltage at service panel before breaker?? Any suggestions?
thanks
Walt
Billy_Bob 02-21-2010 12:48 PM
Intelligent Load Centers...
(Smart breaker panel)
http://www.squared.com/us/products/l...erFrameset.htm
More...
http://ecatalog.squared.com/pubs/Ele...1100HO0601.pdf
Scuba_Dave 02-21-2010 12:56 PM
Shutting off the Main breaker is an illegal setup
Unless he has a lockout breaker/setup installed
So the 1st thing he needs to do is install a legal generator setup
Breaker lockout:
http://www.ecmweb.com/products/8-28-...erator-230.gif
Bondo 02-21-2010 01:17 PM
but there must be something simple that would show when power is restored to house LED at main? Any suggestions?
Ayuh,... Look out the window,+ see if the neighbor's lights are back on....
AndrewF 02-21-2010 01:37 PM
That is basically what I do.
There is a county water tower across the street from me, it has a RED light on top that I can see out the front window. When it is on, I know power is back on ;)
vsheetz 02-21-2010 01:42 PM
If he installed a manual transfer switch that switches over to the generator only selected essential circuits, then when the power came back on one would know by the non-switched circuits coming back on.
VelvetFoot 02-21-2010 06:08 PM
I use one of those voltage detector pen that buzz and lean it up against the conduit containing the mains.
walt1122 02-22-2010 10:55 AM
Thanks all, Velvetfoot that is exactly what I was thinking too. I just wondered if there was anything more "sophisticated"? How do you keep it from sensing the generator voltage? when you are trying to only sense the utility power??
I will check and see if he does have the lock out described. I don't thing so cause he didn't mention that there was anything stopping him from sending generator power through the panel and back throught the meter and causing harm to people working on lines.
We live in a heavily wooded community of roughly 60 home sites (5 acres or so each) with only 5 homes built or under construction. Most of these are weekend homes only two full time residents. we do not see anything except the moon and stars at night and that is why we all bought here. So only thing I could do is tell the neighbor to go out in the storm and see if the little light is on at the meter about 150 feet away from his house on a pole before it goes underground and into his house. Hoping for something better. Some how this all passed the electrical inspection ( not that this makes me feel any better, I did recently post a concern about them using 14g wire on 20A circuit breaker protected lighting circuits in my brand new construction but it appears it is "acceptable" down here??. But I will know more once I do get to see the setup in person.
thanks again for the suggestions and the quick response.
Walt
VelvetFoot 02-22-2010 02:26 PM
That voltage detector has to be pretty close.
VelvetFoot 11-09-2010 10:31 AM
Followup: I'm using Reliance Controls' PowerBack now:
http://www.electricgeneratorsdirect....108/p4112.html
DangerMouse 11-13-2010 07:21 AM
I hope your friend is filthy rich. If he's caught, it's a FIFTEEN THOUSAND dollar fine!!!
(not to mention possible injury to a lineman.)
I got around this problem cheaply, WITHOUT buying a lockout, OR an expensive transfer switch!
I simply ran a string of outlets down the middle of the house that is NOT on the grid at all!
They are powered ONLY by the generator and are normally 'dead' except when the generator is running.
When the power goes out, (a couple of times a year out here in the styx) we just leave one overhead light on (in the living room, normally) and when the lights come back, we go turn off the generator and swap a few plugs. I spray-painted all of the outlet covers for this system Flo. Orange so we can tell the difference easily.
Hope this helps.
DM
a7ecorsair 11-13-2010 09:18 AM
I will check and see if he does have the lock out described. I don't thing so cause he didn't mention that there was anything stopping him from sending generator power through the panel and back throught the meter and causing harm to people working on lines or his neighbors.
Walt
Where do you live?
VelvetFoot 11-13-2010 10:15 AM
Cheap? You have to run the wire in the house, through the walls, etc. Then paint them orange? Then, what's powering all the hard-wired stuff, like furnace, water heater, water pump? I like the lock out for a hundred bucks.
SubSailor 11-13-2010 10:23 AM
interlockkit.com is a ripoff, Square D, Siemens and GE all make interlock kits for their respective boxes, and.... they don't look nearly as stupid as the one scuba posted. and they are less than half the price, I paid 100 bucks for 2 interlocks from Square D and I've seen Siemens selling for 30 bucks
VelvetFoot 11-13-2010 10:36 AM
I agree, but 50 bucks is a great deal. I think I paid about 80 bucks. Then again, everybody gets a better deal than I do. :)
Powered by vBulletin® Version 3.8.8
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
