Long Run Voltage Drop Sub Panel - Electrical - DIY Chatroom Home Improvement Forum
Old 03-21-2010, 04:14 PM   #1
I am requesting help. I have a property 9.4 acre. 900 feet down the drive there will be a local utility transformer and from this location 200a run to 36x58 work shop and another 200a to house another 100ft up the drive.
I want to add a gate at the road with electric gate. I would prefer not to use solar, but have electric motor for gate. I planned the following solution, can someone provide their experience and any mis-calculation in my design.
Run #4 wire to sub panel 60A back up the drive 400ft. From 60a panel run another 300 feet to a double outlet box with #8 wire. Use the double outlet box to run xmas lights and then run another 100 ft of #10 to the gate opener.
The end goal is to have 2 110v 15am circuits about 800 feet up the drive and 1 - 110V 15a circuit at the opener.
I checked with the utility company and they will not allow another meter on property because I will have two already.
Any help would be great.
rkelly is offline   Reply With Quote
Tags
votage drop sub panel
Sub Panel install eagertolearn Electrical 17 01-23-2010 05:39 PM
This doesnt seem right. JoulesWinfield Electrical 27 07-26-2009 07:40 PM
Wire sizing to the condensor zootjeff HVAC 9 06-22-2009 08:02 AM
Use a shared nuetral or not? That is the question. Cyndi Electrical 16 05-23-2008 02:59 PM
Splice in Neutral to Panel - OK or Not? allpraisebob Electrical 4 08-12-2006 05:54 AM
