Location Of Junction Boxes- Built In Oven/cooktop? - Electrical - DIY Chatroom Home Improvement Forum
Old 07-29-2010, 10:53 AM   #1
Question
Location of Junction boxes- built in oven/cooktop?
Hello,
I'm doing a gut reno on my kitchen and I am having trouble figuring out where to put the junction boxes for a 30" built in oven installed under a 30" smoothtop cooktop. At this point in time, there are only studs- no kitchen cabs, no drywall.
The info:
Cooktop- Jenn air JEC0530ADS, installation manual here: www dot tinyurl dot com /2afxave
Oven- Jenn air jjw8330dds, installation manual here: www dot tinyurl dot com /29yokxq
The cooktop manual does not say anything about junction box location, however the oven manual says they recommend the boxes be located in the cabinets on either side. I called a local installer, and they say to locate the boxes IN the oven cabinet. But where? Won't there only be about 1.5" of space to do this in?
I am not sure what to do here. I definitely do not want to install actual boxes in the back of the cabinets, so I will be recessing the boxes into the wall before I close up and then making cutouts in the back of the cabinets so I can run the flex conduit right into the cover- I figure this will give me a bit more room, and I will have the comfort of knowing those junction boxes are secure... Has anyone had experience with this? Am I making this more complicated than it has to be? Is there some simple way to figure this out that I am just not seeing?
Thanks, all!
hamlet is offline   Reply With Quote
Old 07-29-2010, 12:46 PM   #2
anyone??
Old 07-29-2010, 03:49 PM   #3
Rewards Points: 3,130
Cooktops aren't very deep, so box location is less critical. For my built-in wall oven, however, the instructions were very specific about where the box had to go. And if your oven comes with the armored pigtail already attached, you of course need to consider how long it is.
Costs estimate help please for a newbie Basement vs crawl space Cancer Researcher Building & Construction 21 03-30-2012 06:59 AM
DIY phone junction box for cable telephone service eastie Electrical 5 06-17-2009 07:45 AM
Mounting junction boxes in attic, are both of these locations acceptable? diymonkey Electrical 33 04-09-2009 07:24 AM
Location of Junction box Ultrarunner2017 Electrical 5 12-23-2008 06:03 PM
Old House - no junction box - HELP! Designman20 Electrical 22 10-11-2007 04:58 PM
