Load Switch? - Electrical - DIY Chatroom Home Improvement Forum
Old 03-16-2010, 10:17 PM   #1
load switch?
I need some help. I want to switch between two different lights without cutting any power to my ballast. I know I could do this with two different timers, but I would like to have one box between the ballast and the two bulbs to do this function. Just wondering if there is such a product made or if I can create something to work.
Hoblit is offline   Reply With Quote
Old 03-16-2010, 10:23 PM   #2
Just call me Andrew
Rewards Points: 1,032
You want a light switch that will switch between the two bulbs, is that right? Do you want this on some sort of timer? Do you want the switch on the wall?
Andrew
secutanudu is offline   Reply With Quote
Old 03-16-2010, 11:03 PM   #3
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
I gotta ask.
what is the purpose?
Old 03-17-2010, 05:54 AM   #4
Master Electrician
Rewards Points: 5,082
Sounds to me like you want to switch two lamps separately off the same ballast. Don't think that's possible from a single input ballast.
brric is offline   Reply With Quote
Old 03-17-2010, 06:25 AM   #5
Just call me Andrew
Why couldn't he put a 3-way switch between the ballast and the lamps? Feed the ballast into the common, each traveler into a separate lamp.
I'm also curious why.
Andrew
Old 03-17-2010, 06:29 AM   #6
Master Electrician
A switch does not control the output of a ballast it controls the input to the ballast. A 3- way could not do that anyway. One or the other would be one all the time if you did connect a 3-way that way.
Old 03-17-2010, 06:31 AM   #7
Just call me Andrew
Could you explain in more detail why my idea wouldn't work? I believe you, just not understanding fully.
Andrew
Old 03-17-2010, 06:34 AM   #8
Electrical Contractor
jbfan's Avatar
Rewards Points: 968
Voltage rating of the switch comes to mind.
The output voltage on a ballast is far more than the input voltage.
Yes I am a pirate, two hundred years too late
The cannons don't thunder, there's nothing to plunder
I'm an over-forty victim of fate.
Old 03-17-2010, 09:34 AM   #9
nap
You talking to me?
nap's Avatar
so, IF you could find a switch that was rated for the voltage (you need to research what the output voltage of a ballast can be), you have to realize that first, we don't even know what kind of ballast we are dealing with. Is this a fluorescent lamp? HID?
If a fluorescent; instant start? rapid start?
if fluorescent, you have to realize there are at least 2 wires that run to the lamp and up to 4 wires. How are you controlling that many wires with your system?
why I asked what the purpose is is basically because the simplest way to do what he wants might simply be to use 2 ballasts with each connected to their own lamp.
Old 03-17-2010, 04:55 PM   #10
This is actually for something that I am trying with my saltwater tank filtration between two different refugiums. It is a MH ballast. I would like to take one commom wire from the ballast into a timed switch box with two lines out, one to each bulb. I imagine it to work similar to a mechanical timer. Except instead of on and off, the timed switch would transfer the power from one bulb to the other without actually shutting the ballast down. This device would do the job of two timers on the output side of the ballast.
Old 03-17-2010, 04:56 PM   #11
Would there be any way to safely modify a mechanical timer to do this?
Old 03-17-2010, 05:13 PM   #12
nap
You talking to me?
nap's Avatar
I doubt you will find a switch rated to take the voltage. Depending on what kind of lamp and ballast you have, you could experience thousands of volts on start up.
why don't you just install a second ballast?
Old 03-18-2010, 11:21 PM   #13
just looking for alternative options, other than shelling out money for another ballast
Old 03-18-2010, 11:28 PM   #14
nap
You talking to me?
nap's Avatar
I do not think there is a practical alternative.
Double switch wiring rockclimber Electrical 18 03-18-2012 10:13 PM
Wiring double switch for new ceiling fan toolmanwannabe Electrical 17 11-15-2011 09:34 PM
3-way switch help amit Electrical 17 02-15-2010 03:17 PM
HowTo: Adding two exterior lights + switch, piggyback new switch off existing switch? ghost Electrical 14 04-19-2009 05:04 PM
Replacing a bathroom fan switch cmacjr22 Electrical 4 11-04-2008 06:14 PM
