Load Question - Electrical - DIY Chatroom Home Improvement Forum
Old 03-15-2010, 10:59 AM   #1
Load Question
This is a bathroom job. I have the wire going from the panel to the gfci. From the load side it goes to a 4 gang box. The 4 gang goes to the lights and fan as shown. The fan has to be protected due to the location in the ceiling (water)
Is this too much of a load for the load side of a gfci? All this is 20a.
baum is offline   Reply With Quote
Old 03-15-2010, 11:03 AM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 944
Gfci's do not work off load, only an inbalance in current.
The breaker works of an overload.
You should be fine.
The fan is only required to be gfci protected is so stated by the manufacturer, or local codes.
Yes I am a pirate, two hundred years too late
The cannons don't thunder, there's nothing to plunder
I'm an over-forty victim of fate.
Old 03-15-2010, 11:05 AM   #3
Thanks,
I knew the fan was the only one that needed to be protected, but it was easier to just run the 1 input to the 4gang. and branch off from there.
Old 03-15-2010, 11:42 AM   #4
Just call me Andrew
Rewards Points: 1,032
Keep in mind if you GFCI all lights, when the outlet trips you are left in the dark. Feeding your main light (assuming it isn't in the shower) from the LINE side of the gfci (hence bypassing it) is acceptable and common for that very reason.
Andrew
secutanudu is offline   Reply With Quote
Calculating load - 240 load question jamiedolan Electrical 5 10-04-2008 05:26 PM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 08:19 AM
Another Load Bearing Question - Modular Homes ch3howard Carpentry 2 08-17-2008 09:21 PM
hrv question indep HVAC 3 07-17-2008 10:39 PM
