A Little Heat - Electrical - DIY Chatroom Home Improvement Forum
Old 11-30-2010, 11:56 AM   #1
Rewards Points: 150
a little heat
This may be an off topic for this Thread ?
But here I go.
I live in Mi. I have a side porch with a double door, floor to ceiling cabinet.
This porch is not heated but inclosed and insulated with glass windows. around 1/3 of the porch.
the porch size is 6 feet wide by 12 feet long cement floor.
I would like to hang inside the cabinet a 100/w light perhaps two, in an open area above and below in a non flamable area, on a timer to create extra heat on extra cold nights.
This way I do not have to worry about liquid items freezing except when
it turns to 5 F degrees or below.
Now! I normay have to remove all liquids to the basement that has out side entrance only.
(( Would one or two bulbs create just enough heat ? ))
I know I pay somewhere, about .12 to.15 cents per 1,000 watts / this would cost about $7.00 a month extra for three months,
Any opinions ?
Thanks deck hand
deck hand is offline   Reply With Quote
Old 11-30-2010, 03:37 PM   #2
Rewards Points: 2,402
Try:
http://www.heatershop.com/btu_calculator.htm
I don't think two light bulbs will help but it depends on the ambient temperature of course.
bob22 is online now   Reply With Quote
Old 11-30-2010, 04:54 PM   #3
I=E/R
a7ecorsair's Avatar
If your cabinet isn't insulated I don't think you will accomplish much with two light bulbs. Have you monitored the temperature in this porch just to see how much it changes? One thing you could look into is some insulated flooring to cover that concrete.
a7ecorsair is offline   Reply With Quote
VisionPRO Setup Functions & Heat Pump infoskr HVAC 43 07-12-2015 04:28 PM
Comparison and Heat Pump Selection help... ChrisDIY HVAC 7 03-06-2010 08:34 PM
Heat Pump Woes Zenica HVAC 50 01-27-2009 07:37 AM
Heat Pump set back GEAF HVAC 6 01-26-2009 07:49 AM
Which diagram to use on Lenox Thermostat wiring setup? Heat Pump Lenox techs needed twilightcall HVAC 1 08-13-2008 11:49 AM
