Liquidtite Non Metallic Conduit In Crawlspace - Electrical - DIY Chatroom Home Improvement Forum
Old 06-01-2015, 11:07 AM   #1
Rewards Points: 28
Liquidtite non metallic conduit in crawlspace
Wondering if I can use this type of 3/4" conduit for run from junction box mounted on inside cinderblock wall of 4' crawlspace to utility room about 20' for well pump conductors. Got a lot of Ibeams, pillers, etc in way so would be must easier to install due to bends and in a wet location. (3-90 degree bends) I could mount conduit using Ibeam hangers and 2 hole metal straps in concrete piller. But is this type conduit code for this application?
mcclure440 is offline   Reply With Quote
Old 06-01-2015, 11:26 AM   #2
Rewards Points: 2,350
It is OK by code to do but it will look like a hot mess unless you strap it a million places.
Old 06-01-2015, 08:10 PM   #3
Rewards Points: 2,084
You can use it as planned as long as you utilize the proper connectors and strap it every three feet. As someone else pointed out, this conduit tends to sag over time. Also be careful with your bends. It is not that easy to pull wires long distance in this type of conduit and too many curves and bends make it harder.
John Grabowski
MrElectrician.TV
MrElectricianTV is offline   Reply With Quote
Total Degrees of Bend in Underground PVC Conduit tedallen Electrical 12 03-29-2012 08:02 PM
Crawlspace mold repair questions jeep4dog General DIY Discussions 2 11-04-2011 07:03 AM
getting the most out of a heated crawlspace Gerry Fossum HVAC 2 06-08-2011 07:42 PM
Crawlspace Moisture - Serious Problem PaoloM General DIY Discussions 11 12-15-2009 01:35 PM
Sheathing/siding around conduit destroyer427 Building & Construction 1 10-20-2009 05:25 PM
