Lights Using Motion, Switch And Timer - Electrical - DIY Chatroom Home Improvement Forum
Old 11-18-2015, 05:12 AM   #1
MEASURE ONCE, CUT TWICE
123pugsy's Avatar
Rewards Points: 1,590
Lights Using Motion, Switch and Timer
I'd like to hook up my driveway spot lights so that any one of three things will spark them up.
I'd like to put a timer (they do have hard wired timers, correct?), in the utility room and then feed the light switch from there and then to the light which has a built in motion sensor.
Will a 14/3 run from the timer to the switch and then to the light fixture get me there?
I'm roughing in at present.
Pugsy...my project: http://www.diychatroom.com/f49/total...storey-276978/
123pugsy is offline   Reply With Quote
Old 11-18-2015, 05:55 AM   #2
Rewards Points: 808
Yes it will.
IslandGuy is offline   Reply With Quote
The Following User Says Thank You to IslandGuy For This Useful Post:
123pugsy (11-18-2015)
Old 11-18-2015, 09:50 AM   #3
123pugsy's Avatar
Thanks Island Guy.
My friend told me there is a timer/switch that fits in the space of a Decora light switch. Sweet.
Old 11-18-2015, 10:08 AM   #4
Rewards Points: 808
Yes, I have this timer in my garage. It feeds a photocell. The timer is set for noon until 10pm, so the lights come on at dusk via the photocell and off at 10pm via the timer. It comes on again in the morning for 1 & 1/2 hours to illuminate my escape to work.
There are 3 motion sensors under my eves which will also trigger the lights on whenever A-it's dark out and B-there's motion sensed and C-the timer happens to be off. So anyone coming/going after 10pm isn't left in the dark.
There is a 2-wire cable (GFCI protected) feeding the timer, a 3-wire from timer to the photocell. From the photocell there is a 2-wire to the receptacle that the landscape lights are plugged into, and also from the photocell there is a 3-wire cable to the 1st, 2nd, and 3rd motion sensors.
Old 11-18-2015, 02:32 PM   #5
123pugsy's Avatar
Thanks.
Just like you posted above:
I was just talking to my buddy and told him I wanted the timer to shut down at 10 PM.
He tells me his is turning on via the photocell but that he needs it to turn on early in the morning for when his daughter is leaving for work. He hasn't hooked up his timer yet.
I'm not allowed to put a receptacle in my lighting circuit. All exterior outlets must be on one dedicated GFCI circuit. Just as well as I'm not using any landscape lighting.
Adding timer to 3-way switch Strobie Electrical 5 12-06-2014 01:18 PM
Installing Honeywell 3-way timer switch PLS750C Jaluddeke Electrical 11 10-10-2014 03:20 PM
A few wiring questions on installing this timer switch thinksincode Electrical 19 03-04-2013 05:31 AM
3 way switch trips breaker over night Hazelberg Electrical 5 09-21-2012 09:34 PM
Can you override outdoor lights on a timer w a switch? dbldee20 Electrical 2 11-08-2011 05:36 PM
