Lighting Fixture Safety Standards - Electrical - DIY Chatroom Home Improvement Forum
Old 12-27-2009, 01:12 PM   #1
Rewards Points: 726
Lighting fixture safety standards
So the standard is to have Hot on the tip and neutral on the screw base, but in the case of a chandiler, how do you know which is witch? The cords I have on the chandilers in my house are all that yellow clear brassey looking coard... I just wanted to check to see if they are up to the "safety" standard is there any real way to check this with out disassembling the chandiler and looking what is connected to what? thanks!
BlueBSH is offline   Reply With Quote
Old 12-27-2009, 01:39 PM   #2
Electrical Contractor
wirenut1110's Avatar
Rewards Points: 510
Send a message via AIM to wirenut1110
I forget whether it's the hot or neutral(I usually ring them out) but, if the cord has the same color conductors, the cord will have some kind of distinguishing marks whether it be writing on one conductor or one conductor will be ribbed.
wirenut1110 is offline   Reply With Quote
Old 12-27-2009, 01:49 PM   #3
Rewards Points: 726
Unfortinuatly, I'm not seeing anything like that on these cords...
Old 12-27-2009, 01:56 PM   #4
Rewards Points: 510
If you have no way of checking continuity maybe someone else has an idea.
Old 12-27-2009, 02:29 PM   #5
Rewards Points: 726
might end up having to take the top off them and see whats connected to wha, I'm sure inside they have white and black lines... most of them I've seen do... just gets to be a pain sometimes taking it apart to check that
Old 12-27-2009, 03:51 PM   #6
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
generally on a zip cord, there will be a small rib on one of the sides. That is intended to be the neutral. I have also seen much of it with the (intended) neutral conductor to use tinned wire. It will look silver and the hot wire is left plain copper.
the rib is not overly noticeable so you do have to look (actually I have to feel) quite closely.
and BlueBSH, it is not just a standard for the shell to be the neutral, it is a code requirement.
the easiest way is to use a continuity tester and check from one prong of the plug (if a plug is used) to the lamp socket. The larger blade is the neutral which should be the shell of the lamp holder.
Old 12-29-2009, 08:33 PM   #7
Rewards Points: 726
picked up a Voltage sensor at lowes for about $10 said on the packadging can detect hot wire, so figured try it out... seems to work great detecting where the hot is in a screw base... touch it to the screw part doesnt go off.. touch it to the tip part and goes off found one light fixture in the house that needs flipped, so seems to be a good $10 investment
Old 12-29-2009, 10:03 PM   #8
How to use a continuity tester...
http://www.dinosaurelectronics.com/Test_Fuse.htm
Note: Remove all light bulbs first and disconnect power.
Billy_Bob is offline   Reply With Quote
DIY Lighting Fixture stubits Electrical 11 10-13-2009 01:20 PM
Help with a lighting fixture llVeXXll Electrical 2 09-16-2009 09:29 PM
Adding recessed lighting where old fixture was ConstantChange Electrical 4 01-15-2009 04:42 PM
Installing Lighting Fixture lilsara88 Electrical 3 01-03-2009 08:49 PM
Safety Concern related to bathroom light fixture sooner2k1 Electrical 3 01-10-2008 08:57 PM
